thank you steve but i dont think we are talking about the same thing
i don't think i did a very good job explaining myself
-- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@...> wrote:
> I'm not clear on what you want to do, so let me try (1) bouncing
> back something that I think you might be trying to do and (2)
> suggesting something that might directly or indirectly help get you
> where you want to go.
> (1) Are you saying that you want to create (for example) one
pattern
> in the sequencer that plays through a number of times in such a way
> that the arp pattern differs as the sequencer pattern repeats?
> (2) As a memory aid, use a system of naming presets and assigning
> arps to those presets that helps. For example:
> Rp0:Sound00+Arp00 = a sound you will use + User Arp 00
> Rp1:Sound00+Arp01 = the same sound + User Arp 01
> etc.
> Tip: The preset navigator finds caps before lower case letters;
> that's why I used Rp for the prefix.
> Again, I am not sure if any of this applies to what you want to do,
> but I mention just in case they help.
> --Steve
> --- In xl7@yahoogroups.com, "zombilimited" <zombilimited@> wrote:
> > okay due to the lack of response let me get more specific with my
> question :P if i edit arp
> > settings within a preset bass and save it to a user sound slot i
> would have to remember
> > when using that same preset sound later with different arp
> settings in a different pattern
> > not to save over the same user sound or i will mess up the
pattern
> in which i used the
> > preset sound in before....this seems a little complicated there
> must be an easier way my
> > my lackluster mc303 saved arp settings within a pattern although
> you couldnt create your
> > own sounds and save them on that.....ive read the manual please
> tell me
> > if i write a pattern and want to change the arp settings for a
> sound and have them show up
> > everytime i play the pattern from step 1 to finish how would i do
> it ....thanks for taking the
> > time..don't want to write a whole bunch of patterns to do it
wrong
> and mess my patterns
> > up........thank u for your time in advance
