tried again and again,failed to upgrade os
2001-09-13 by dj4tunes@yahoo.com
hi scott
i checked the "show midi device(or whatever...)" on e-loader,it
showed:
emu systems xl7-mfg id-24 mod id-44013 deviceid-0 revlevel-80764856
(plos).
i think it can detect i hooked the xl7,right?
i tried again,and also select the "extreme" instead of "default
program" at the preference option.(also,i didn't select anything and
it's set at default prog. itself when i tried to upgrade the os many
many times b4).
after i power on the xl7(by pressing home/enter and on/off at once of
course),the xl showed "searching for os..._ " and the e-loader
showed "download request received" then i pressed the "download os
file to target" soft button,and the xl7 red midi in led indicator did
flash once(just once,less than half sec.)then i again stuck in the
same situation(xl7 said "searching for os..._ and midi out repeatedly
flashed" and the e-loader showed "download request received".)
i waited over 15 mins (i think if its in proper process just need
several seconds to a min ,right?) then exit the e-loader.
then i power off the xl7.re-open the e-loader,the e-loader big logo
graphics just stuck my pc,i had to do"ctrl/alt/del" to exit from it.
is this a bug of the e-loader too?(sometimes the top left small
rectangular menu bar just displayed half the graphic horizontally...)
thats all i did,any suggestion?pls help.
the glitches and delay between the patterns are too ugly
listening,even a non-musician/hobby listener can hear it.
thanks
dj4tunes
Re: [xl7] tried again and again,failed to upgrade os
2001-09-13 by Dietmar Koering
hve you asked one if there is any other cahnge to upgrade the os.... ? I now
that the most synths can be upgraded via MIDI vfiles played in a
sequencer... maybe you should load the os in cubase or etc. and connect the
midi out from da pc tu da midi in with the xl-7..I don\ufffdt know, but may be it
works..... I bougt my xl-7 3 weeks ago with the new os...  good luck
greetz
dietmar
To: <xl7@yahoogroups.com>
Sent: Thursday, September 13, 2001 10:46 AM
Subject: [xl7] tried again and again,failed to upgrade os
> hi scott
> showed:
> (plos).
> many times b4).
> thanks
> dj4tunes
> To unsubscribe from this group, send an email to:
> xl7-unsubscribe@yahoogroups.com
Re: tried again and again,failed to upgrade os
hi dietmar
thx 4 ur reply
do u think the cakewalk(i'm using) can accept the .dli file(the
xl/mp7 os file) and load them in the song?
can ur cubase do that?
thx
dj4tunes
os.... ? I now
connect the
> midi out from da pc tu da midi in with the xl-7..I don t know, but
may be it
> greetz
> dietmar
> From: <dj4tunes@y...>
> To: <xl7@y...>
> > hi scott
> > showed:
80764856
> > (plos).
and
many
> > many times b4).
once of
did
repeatedly
logo
it.
horizontally...)
> > thanks
> > dj4tunes
> > xl7-unsubscribe@y...
Re: [xl7] Re: tried again and again,failed to upgrade os
sorry  I thought it would be a midi file.... maybe yuo should give a mail to
emu....
Sent: Thursday, September 13, 2001 8:24 PM
Subject: [xl7] Re: tried again and again,failed to upgrade os
> hi dietmar
> thx 4 ur reply
> thx
> dj4tunes
> os.... ? I now
> connect the
> may be it
> > greetz
> > dietmar
> > To: <xl7@y...>
> > > hi scott
> > > showed:
> 80764856
> > > (plos).
> and
> many
> > > many times b4).
> once of
> did
> repeatedly
> logo
> it.
> horizontally...)
> > > thanks
> > > dj4tunes
2001-09-13 by Sean Wilhelmsen
dj4tunes@... wrote:
> hi dietmar
> thx 4 ur reply
> thx
> dj4tunes
No, it requires E-Loader.  I would suggest now you contact your local
E-MU service center to arrange am E-PROM update.
sean at e-mu / ensoniq
hi sean
i think its quite a trouble 'coz i ordered it from the states and i'm
in asia somewhere and there's no official agent here i think.
the shop told me the xl7 should come w/ the update v1.01 os(i've just
received it on 11sept.)but as a result,its a v1.0
do u think i can upgrade the e-prom by myself after i ask ur company
or the shop to send me the e-prom?
or any further solution from scott,'coz he offered some suggestions
to me on this group,tho they're not useful for my case.
thx
dj4tunes
--- In xl7@y..., Sean Wilhelmsen <seanw@e...> wrote:
> dj4tunes@y... wrote:
> > hi dietmar
> > thx 4 ur reply
> > thx
> > dj4tunes
local
E-mail me privately with your address and I'll send you out an E-PROM
kit. I believe you'll be able to update it yourself. You still will want
to get your E-Loader working since 1.01 will not be our last OS upgrade
for the Xl-7.
dj4tunes@... wrote:
> hi sean
> thx
> dj4tunes
> > > hi dietmar
> > > thx 4 ur reply
> > > thx
> > > dj4tunes
> local
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2001-09-14 by Scott Ruda
On Thursday, September 13, 2001, at 01:46 AM, dj4tunes@... wrote:
> hi scott i checked the "show midi device(or whatever...)" on e-loader,
> it showed:
> (plos).
This essentially looks correct (you have not typed it 'exactly' as
reported) but it does seem like it is connected bi-directionally. Are
you able to transfer Sequence files using E-Loader? Are you able to play
MIDI notes by mousing around in the MIDI Tracker window? Can you see
activity in the MIDI Tracker window when you play the XL-7?
This only changes the Appearance (color scheme) of the application -
just a simple 'skinning' choice. It doesn't need to be set to any
particular value for the MIDI operation to work :-)
After choosing to Download on E-Loader, the screen on XL-7 should change
to 'MIDI Download' nearly instantly. If it never does that, it is not
receiving even the first MIDI message from E-Loader correctly.
Again, please tell me what version of OS and what version of Java are
you running. This information will be displayed in the Message Console
(found in the Window menu). It would be best if you send me (off list)
the entire log file.
As I stated before, these problems, although annoying, should not stop
the MIDI aspects of E-Loader from working. Once you have a problem like
this, it would be best to reboot your system to make sure it has a clean
slate when starting E-Loader next. We are actively working to fix this
problem, but meanwhile it should not be stopping you from updating the
OS on your XL-7, which is what's most important ;-)
I'm sorry you are having these problems. E-Loader seems to be working
fine for most users, so there is something unusual about your setup that
we haven't yet been able to isolate. As Sean said, you can contact him
to get a ROM update kit in the mail to you, but it would be good for
both you and E-mu to understand why this is not working for you. If you
don't mind to continue to troubleshoot this, we should probably take the
rest of our work off-list. If we find a problem that is pertinent to the
rest of the list, we can post our conclusions afterwards.
Scott
2001-09-14 by dj4tunes@yahoo.com
--- In xl7@y..., Scott Ruda <scottr@e...> wrote:
loader,
> > it showed:
80764856
> > (plos).
Are
play
see
i haven't tried these(tranx seq.or play midi via midi traker),but i
checked again my midi interface's midi i/o to verify its
functionality,it works.
and
once of
did
repeatedly
change
not
are
Console
list)
well,i'll copy the log.txt to ur private email address.
logo
it.
horizontally...)
stop
like
clean
this
working
that
him
for
you
take the
to the
i'd like to get the update e-prom and also like to try to fix it b4
the e-prom arrive me here.
thanks
> Scott
sean
ok,i'll send my postal address to ur private email address.
and pls send it along w/ an installation guide.
do u think when will it arrive my place?
does the u.s. airports back to the normal working condition?
thanks
PROM
want
upgrade
> for the Xl-7.
> > hi sean
i'm
just
company
suggestions
> > thx
> > dj4tunes
> > > > hi dietmar
> > > > thx 4 ur reply
(the
> > > > thx
> > > > dj4tunes
> > local
Service.
