Pattern Sets for Other ROMS
2008-06-12 by Donn
Hi:
I have looked quite a bit but so far cannot find sources for these, but:
1) are there any significant pattern collections out there for Proteus ROMs other than the
normal command station ROMs?  As far as I know, there's only factory patterns for only
PX7, XL7, MP7 and P2500.  What about pattern sets for TSCY, Beat Garden, Vintage Pro and
other ROMs?
2) has anyone done any work with or attempted to automatically translate the factory
patterns into patterns for other ROMs?  My understanding is that the patterns are nothing
more than short MIDI phrases with ROM and patch selection info embedded.  So if one was
to 'decompile' it, it would make the work of substituting patch selections from another
ROM quite easy, while expanding the sonic phrase palette of a command station
significantly.
3) and along the same lines, has anyone tried translating the patterns / phrases from
other similar products (Yamaha RS7000, Roland MC909, etc.) and translate them into
patterns for the command stations (both standard and optional ROMs?)
My guess is some programmer could easily write up a translator program that would
semi-automate this process, making it very easy to generate a much expanded set of
patterns.   Seems like it would be a great way to expand the value and versatility of the
Command Stations.  These are awesome boxes.  Yes, you can build your own patterns with
some incredibly powerful voice tweaking options and what-not.  But it takes quite a bit of
effort and time.  Also, many of the newer 'groove boxes' come with multiple hundreds of
phrases / patterns with stock units.  Why should we at most only have 128 for a given box
/ ROM?
Any info would be much appreciated.
Peace & blessings,
Donn
Re: Pattern Sets for Other ROMS
2008-06-12 by steve_the_composer
--- In xl7@yahoogroups.com, "Donn" <donnw2@...> wrote:
> Hi:
these, but:
> other ROMs?
I think it was the Orbit Yahoo Group that used to have a new set of
TSCY arps from Rob Papen that would work with any P2K based E-Mu
module/Sound ROM. (See also below about transferring ROM-based riffs
to patterns.)
command station
> significantly.
You can do this manually by simply loading the presets into your
sequencer and changing the presets. You could also use a software
sequencer. For example, I have a P2500 with an XLEAD ROM (from an XL-
1). So in SONAR, I loaded XL-7 Factory Patterns and reassigned them
to XLEAD Presets.
translate them into
ROMs?)
program that would
expanded set of
> / ROM?
I think many people are busy creating their own patterns.
But here's a tip you might like if you want to expand your inventory
of patterns.  As you may know, riffs are ROM-based patterns that you
cannot edit or use. However, you can set your box to transmit riffs
(and/or arps) and record them as patterns by taking the midi out and
putting it into the midi in.
> Peace & blessings,
> Donn
Hope this helps.
--Steve
