Re: [pk6] Re: HELP!!!!!!!!
2008-07-12 by Bob S.
Glad to hear at least part of the PK-6 works.....but I would verify first that the Proteus 1000 ROMs are compatible with the PK-6/Proteus 2000 series....I myself am not sure of that....
Bob
El Segundo, CA
  To: pk6@yahoogroups.com
  Sent: Saturday, July 12, 2008 6:58 AM
  Subject: [pk6] Re: HELP!!!!!!!!
  Hey all thanks for the responses. Regardless of whether or not I
  can get this PK-6 completely restored, I won't be selling it anytime
  soon as it still functions just fine as MIDI controller. Another
  user sent me an OS update so, using E-Loader, I successfully
  updated the OS from 1.0 to 1.02. Unfortunately that did'nt fix
  the problem. I'm starting to think that perhaps the original
  ROM was damaged. In any case, I have a Proteus 1000 on the way
  so I'll be able to test the ROM. I only paid $150 for PK-6 so
  even if I can only use it as a controller I'm not too upset.
  Cheers.....Cristofe
  http://www.myspace.com/cristofe
  --- In pk6@yahoogroups.com, "Bob S." <tttsystems@...> wrote:
  > Aaron is the Emu guy in the XL7 group.....you saw his response....
  > The good news for Cristofe in the PK-6 group (bad news for PK-6
  owners like myself) is that the PK-6 hit a new resale low on Ebay
  this week, $225 with ROM.......
  > The bad news sounds like it may take some work, repair and/or
  reprogramming to get that PK-6 up and running......anyone need spare
  parts that Cristofe could sell from the PK-6 to minimize his
  losses..........
  > Bob
  > El Segundo, CA
  > >From: Triphammer <schtuup@...>
  > >Sent: Jul 10, 2008 11:04 AM
  > >Subject: [pk6] HELP!!!!!!!!
  > >Ok, first let me say....I'M A DUMB@SS!! I just got a PK-6 and it
  WAS
  > >working fine. But I just can't leave well enough alone. I had an
  > >Audity 2000 ROM lying about and, while I thought it probably
  would'nt
  > >translate correctly, I thought at the very least I could get some
  > >interesting noise out of it and at the very worst it simply
  would'nt
  > >work.....WRONG!! My PK-6 is now completely F*CKED!! It no longer
  > >recognizes the original PROM and to make matters worse I re-
  initialized
  > >it and wiped out my user presets now I'm left with deafening
  silence!
  > >I've run the diagnostics and the ROM passes the #14 sound rom test
  > >but when I run the #16 sound data CRC test it reads "invalid" on
  both
  > >slots 1 & 2. Have I ruined the original ROM?? Any advice here would
  > >be GREATLY appreciated.
  > >TIA....Cristofe
2008-07-17 by Bob S.
A couple of things...you assume the PK-6 or P2500 ROM is backwards compatible with the P1000....it is a good possibilty that the P1000 OS is old enough that it will not recognize any of the newer ROMS that were not around when it was made.  This was a problem in the early P2Ks also.
Also, you said nothing about slots 3 & 4 on the PK-6.....
Bob
El Segundo, CA
  Sent: Thursday, July 17, 2008 6:33 AM
  Subject: [spamcatcher] Re: [pk6] Re: HELP!!!!!!!!
  I got the Proteus 1000 in and my worst fears are true. Both the PK-6
  AND its original ROM are toast. I thought the ROM was a "Composer"
  but its a "P2500". The 1000's "Composer" ROM still gives a test #16
  reading of invalid on slots one and two in the PK-6 and when I put
  the PK-6's ROM in the 1000 I got a message of "Error SIM with two ROM
  ID's". The PK-6 ROM does pass the #14 test. A very knowledgable E-Mu
  guy suggested that the PK-6 "P2500" ROM might somehow be re-flashed?
  That would make me REALLY happy!! I like the P2500 soundset better
  than the Composer set...fits my style better. I could then install it
  in the Proteus 1000's second slot and use the PK-6 as a controller as
  it still works fine in that capacity. I wonder if there isn't some
  easy fix for the PK-6 itself as ALL other functions except reading
  the ROMs seem to be ok.
  Cheers.....Cristofe
  --- In pk6@yahoogroups.com, "Triphammer" <schtuup@...> wrote:
  > Great! Thanks again!! The 1000 should be delivered tomorrow.
  > Hope I can sleep tonight!!....;)
  > Cheers.....Cristofe
  > --- In pk6@yahoogroups.com, "Speedy Johnson" <o.johnson1@> wrote:
  > > I don't know about the export. Try it and see. Let me know and
  > I'll help you if I can.
  > > From: Triphammer
  > > Sent: Monday, July 14, 2008 7:35 AM
  > > Thanks very much for the offer but I should be able to export
  > > it from the Composer ROM in the Proteus 1000 no? Or do I need
  > > specific PK-6 Composer sysex?? If that's the case then YES
  > > PLEASE!!
  > > So then is there a way to re-flash the ROM without an Ultra
  > Sampler?
  > > Can I just install both ROMS in either the Proteus or PK-6 and
  > copy
  > > one to the other?
  > > Thanks again to all for your help and advice in this troubled
  > time!!
  > > BTW....I'm selling that A2K,(and a bunch of other goodies!), on
  > > eBay this week if anybody needs one for parts.
  http://shop.ebay.com/merchant/cristofe_W0QQ_nkwZQQ_armrsZ1QQ_fromZQQ_m
  > > doZ
  > > Cheers.....Cristofe
  wrote:
  > > > If the ROM i still good, do you need a SYSEX of the Composer
  > data?
  > > > From: Triphammer
  > > > Sent: Saturday, July 12, 2008 3:15 PM
  > > > Oh believe me, I checked all that before I plunked down more
  > > money!
  > > > The 1000 uses the same Composer ROM as the 2000 and it does
  have
  > > > the same engine albeit with reduced polyphony. The main
  > > differences
  > > > are physical...no multiple outs, just stereo and no spdif
  out.
  > > Also
  > > > it has just the one expansion slot. I'm a tech so, of course,
  I
  > > never
  > > > handle anything without a groundstrap and I'm careful not to
  > > install
  > > > backwards....just wish I had better sense when I thought
  about
  > > > installing that Audity ROM.....DOH!! If the original ROM in
  > > PK-6
  > > > turns out to be good I'll just re-sell it as its the same
  > soundset
  > > > as the one in the 1000. Between what ROMS are selling for
  these
  > > days
  > > > and the great deal I got on the PK-6 to begin with I may
  > actually
  > > > end up with a free controller AND a couple extra dollars!!
  > > > Thanks again for the help and advice!!
  > > > Cheers.....Cristofe
  > wrote:
  > > > > I believe the Proteus 1000 and 2000 series have the same
  > > internal
  > > > engine. The difference, as I recall, is that the 1000 series
  > can
  > > > accept only a single ROM wheras the 2000 series and the PK6
  > > series
  > > > can accept up to four ROMS. Got to ensure the ROMs are not
  > > installed
  > > > backwards. It can be done even though the slots and the ROMs
  > are
  > > > keyed. Just be careful. Also need to be sure you utilize a
  > > grounding
  > > > strap so you don't Zap the ROM. A little precaution doesn't
  > hurt.
  > > > > I can't remember eactly which ROM the P2K uses-- the
  Composer
  > > or
  > > > the other one. Same exact multisamples but different ID
  numbers
  > > and
  > > > preset names.
  > > > > From: Bob S.
  > > > > To: pk6@yahoogroups.com ; xl7@yahoogroups.com
  > > > > Sent: Saturday, July 12, 2008 8:31 AM
  would
  > > PK-
  > > > > Bob
  > > > > El Segundo, CA
  > > > > From: Triphammer
  > not I
  it
  > > > anytime
  > Another
  fix
  way
  so
  > > > > Cheers.....Cristofe
  > > > response....
  for
  > PK-
  > > 6
  on
  > > Ebay
  > and/or
  > need
  > > > spare
  his
  > > > > losses..........
  > > > > > Bob
  > > > > > El Segundo, CA
  > > > > > -----Original Message-----
  > > > > > >From: Triphammer <schtuup@>
  6
  > > and
  > > > it
  > > > > WAS
  I
  > > had
  > > > an
  > probably
  > > > > would'nt
  > get
  > > > some
  > simply
  > > > > would'nt
  no
  > > > longer
  > re-
  > > > > initialized
  > deafening
  > > > > silence!
  sound
  > > rom
  > > > test
  > > reads "invalid"
  > > > on
  > > > > both
  > > here
  > > > would
  > > > > > >TIA....Cristofe
2008-07-29 by fretsmax
If you are getting no power and or no sound then it most likely is a
bad connection.  It took me two hours to put a new rom (proteus2000) in
my XL-7
It doesn't just slide right in like a pci card or roland expansion slot.
I just got the proteus2000 rom and I'm loving it.
