Re: [xl7] Keep getting not installed error on XL7 try this
2008-09-13 by Angelo
are u trying to get the sounds out through a midi controller?
if you are make shure the cc32 is set to 0
and the cc00 is set to 0
or it will say not installed!!!
will the demo song play?
if it does you still have the sounds there
hope this helps you
  To: xl7@yahoogroups.com
  Sent: Friday, September 12, 2008 3:09 PM
  Subject: Re: [xl7] Keep getting not installed error on XL7
  The OS loads but when I try to access the XL7 rom it says "not installed'. Then if I move the jog wheel the user presets show up but they have no sound rom to go off of, and no sound comes out. I think it is a software problem. Thanks for your advice, I hope I can still fix it.
  --- On Thu, 9/11/08, Ty Rodgers <solacerodgers@...> wrote:
  > From: Ty Rodgers <solacerodgers@...>
  > Date: Thursday, September 11, 2008, 3:12 PM
  > does it say no sound rom found when you go to select a
  > sound? That happened to my mp7 and i was never able to fix
  > it. I checked everything man. sorry to hear that.
  > --- On Thu, 9/11/08, grandfunkemperor
  > <grandfunkemperor@...> wrote:
  > From: grandfunkemperor <grandfunkemperor@...>
  > Subject: [xl7] Keep getting not installed error on XL7
  > Date: Thursday, September 11, 2008, 7:13 PM
  > I have an XL7 with it's original rom and it claims it
  > is not installed, although it is. I have tried
  > loading it in every slot and I still get "not
  > installed" when trying to get at my sounds. All my
  > present and custom pattern info is still there, midi works
  > fine, just no sound. I had removed
  > it and reinstalled it when I was having startup issues and
  > now it loads fine minus the sounds.
  > Any help would be greatly appreciated. Thanks.
2008-09-13 by Bob S.
That's interesting info on the cc's.....how did you find that out ?
Bob
El Segundo, CA
  Sent: Saturday, September 13, 2008 2:23 PM
  Subject: Re: [xl7] Keep getting not installed error on XL7 try this
  hope this helps you
2008-09-14 by Angelo
when i used the roland a-33 controler to my proteus2000
i found out when i tried to change patches
the NOT INSTALLED would show up
I then figured out that the controller
was sending something to the emu that did not agree
So then i played around with the cc32 and the cc00 buttons on the controller
and set them to the user bank 0 of the Emu
and it worked
  Sent: Saturday, September 13, 2008 6:03 PM
  Bob
  El Segundo, CA
  hope this helps you
2008-09-14 by Ty Rodgers
I have a emu mp7 that i have never hooked a external controller to is there anyway this might have also happened to mine as it says no sound roms installed on mine? How would i go about to change this or test it.
Date: Sunday, September 14, 2008, 12:48 AM
and it worked
To: xl7@yahoogroups. com
Bob
El Segundo, CA
hope this helps you
--- On Thu, 9/11/08, Ty Rodgers <solacerodgers@ yahoo.com> wrote:
> From: Ty Rodgers <solacerodgers@ yahoo.com>
> <grandfunkemperor@ yahoo.com> wrote:
> From: grandfunkemperor <grandfunkemperor@ yahoo.com>
Re: Keep getting not installed error on XL7 try this
2008-09-14 by steve_the_composer
Bank switching involves three parameters:
ROM ID [MSB]
ROM BANK [LSB]
Program Change
MIDI Spec defines controllers 0 and 32 for bank switching; you also
need to send a program change in order for the swicth to take effect.
If you have no controllers or devices hooked up to your gear (either
hardware or software), you could still accidently switch to a bank
you don't have. That would result in the "NOT INSTALLED" message.
--Steve
controller
> and it worked
>   ----- Original Message -----
>   From: Bob S.
this
out ?
>   Bob
>   El Segundo, CA
>   From: Angelo
this
>   hope this helps you
>   From: phillip deverell
still fix it.
Re: [xl7] Re: Keep getting not installed error on XL7 try this
This is really good news as i was about to scrap my mp7 because i was SURE i some hoe messed up the rom board. I have been trying to figure this out on mine for some time so I just have to switch those.
--- On Sun, 9/14/08, steve_the_composer <smw-mail@...> wrote:
Subject: [xl7] Re: Keep getting not installed error on XL7 try this
Date: Sunday, September 14, 2008, 1:17 PM
ROM ID [MSB]
ROM BANK [LSB]
Program Change
--Steve
controller
> and it worked
> From: Bob S.
this
out ?
> Bob
> El Segundo, CA
> From: Angelo
this
> hope this helps you
still fix it.
> --- On Thu, 9/11/08, Ty Rodgers <solacerodgers@ ...> wrote:
> > From: Ty Rodgers <solacerodgers@ ...>
> > <grandfunkemperor@ ...> wrote:
> > From: grandfunkemperor <grandfunkemperor@ ...>
2008-09-14 by Aaron Eppolito
CC 0 and 32 are simply bank select messages.  They correspond to the ROM ID and Bank ID respectively.  If you press Audition, the MSB and LSB numbers are 0 and 32.  Changing them won't do anything different than changing them on the main screen.
For the not installed folks, try putting your cursor under the ROM ID in the UI.  It's in the upper right of the preset screen and will say "User" or "XL-7" or "XLEAD" or any of the other ROMs.  If you don't see your ROM there, it's not plugged in.  If you do, and you're still getting not installed messages, check your presets.  The Instrument page will show you what ROM it's trying to access.
-Aaron
Sent: Sunday, September 14, 2008 8:01:10 AM
Subject: Re: [xl7] Re: Keep getting not installed error on XL7 try this
ROM ID [MSB]
ROM BANK [LSB]
Program Change
--Steve
controller
> and it worked
> From: Bob S.
this
out ?
> Bob
> El Segundo, CA
> From: Angelo
this
> hope this helps you
still fix it.
Yahoo! Groups Links
That is a great point about checking the Instrument ROM settings. If
someone switches around ROMS in their gear and has a preset using an
Instrument that is on a ROM that is no longer installed, that's a
problem.
--Steve
> -Aaron
this
> From: steve_the_composer <smw-mail@...>
> ROM ID [MSB]
> ROM BANK [LSB]
> Program Change
also
effect.
(either
> --Steve
> controller
> > and it worked
> > From: Bob S.
> this
> out ?
> > Bob
> > El Segundo, CA
> > From: Angelo
> this
> > hope this helps you
can
> still fix it.
