Using riffs in Patterns.
2009-02-25 by slipknotfkr
Hello All,
Newbie here... Just got an MP-7 off Ebay I haven't had a whole lot of
time to play with this baby and I'm itching to show my ignorance. My
question is. Is there a way that I can record the riffs into a
pattern? Or are they just designed to be used in live situations.
Thanks in advance,
Dave
Re: Using riffs in Patterns.
2009-02-26 by steve_the_composer
Set unit to transmit riffs.
Turn TRANSMIT MIDI CLOCK off
(so you don't feedback midi clock data).
Run midi out to midi in.
Record riff into pattern.
I think this is described in one of the FAQs (see files).
--Steve
--- In xl7@yahoogroups.com, "slipknotfkr" <carrda@...> wrote:
> Hello All,
of
> Thanks in advance,
> Dave
from FAQ v102:
Recording Arp and RIFF Patterns to a Track
Connect a midi cable from the midi out to the midi on of the MP-7, and
make sure MIDI Thru is off. You may need to manually erase
the 'trigger' note, as well as shift the start times of the arp notes
too if they are delayed slightly. Very easy to do with OS 2.0 BTW.
- rEalm
RE: [xl7] Re: Using riffs in Patterns.
2009-02-26 by dc
Steve, Thanks a lot for the info. I will read those FAQ s very carefully. Thanks, Dave ... From: xl7@yahoogroups.com [mailto:xl7@yahoogroups.com] On Behalf Of
