volume peak
volume peak
2010-04-29 by Atom Smasher
another hack. one of the filters has a bad peak in volume at the middle of
the cutoff freq, making filter sweeps not so smooth. i could put a
limiter/compressor on it... or i could fix it with cords...
  1) Diode  ->  AmpVol   +100
  2) DC     ->  Diode    -50
  3) MidiA  ->  Diode    +100
  4) MidiA  ->  AmpVol   -10
  5) MidiA  ->  FiltFreq +100
  #1 adjust as needed
  #2 determines at what point the volume increases
  #3 determines the rate that volume increases, after overcoming the offset
of #2 and accounting for the decrease of #4; in my case this increases the
volume as #5 is turned from 50-100%
  #4 controls the initial rate of volume decrease; in my case it
compensates for the unwanted increase in volume that would otherwise occur
as #5 is increased between 0-50%
  #5 is the filter cutoff; without the other cords it was giving a peak in
volume as it passed through the middle of the range.
this can be modified to make something happen more, or happen less, as a
knob or other controller (env? LFO?) passes the halfway point between
0-100. of course the halfway point is adjustable, and the controller can
be doing something else at the same time.
enjoy...
i'm starting to like this synth ;)
         ...atom
  ________________________
  http://atom.smasher.org/
  762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808
 	"I recognize that a class of criminals and juvenile
 	 delinquents has taken to calling themselves
 	 'hackers', but I consider them irrelevant to the
 	 true meaning of the word; just as the Mafia calls
 	 themselves 'businessmen' but nobody pays that fact
 	 any attention."
 		-- Robert Bickford
