FLASH Progress Report
2010-10-14 by Jack Pratt
Have been very busy, what with home renovations, computer problems, flooding,
etc...
I finally have been able to finish off the PCB layout for the USB programmable
FLASH SIMM {top & bottom layers attached so you can see that its pretty full}.
It was a lot of effort because I tried to use 8mil (0.008") track and space to
reduce board cost but that was a dead cause, and finally I opted for 6mil track
and space. I toiled long and hard to fit in on a 4 layer PCB and only just made
it, but I had no way to place a USB connecter, other than a 4 pin header so a
special cable will be needed for USB connection... We'll have to see how much
the PCB costs (per item)
I need to check that the CPLD can still be programmed after the pin
re-arrangements that I made to help it fit but I don't expect that to be a big
problem.
I needed to make the SIMM 1.1" x 4.25" (the E-mu ones are only 1" high) to make
room for the JTAG headers - this should still fit in the modules fine by my
reckoning. The idea is that the SIMM gets turned upside down into a socket with
the notch removed for JTAG programming.
Fortunately I was able to procure a copy of the EOS TSM from E-mu which includes
schematics for all the E4 series products including the ULTRA samplers. Despite
assertions that some people have made to the contrary, there is no signal on the
Ultra to drive the PRESET line (to access the preset memory) so there is NO WAY
the Ultra can write to a FLASH SIMM's preset memory  [if you see dummy presets
on a p2k, then the p2k created them, not the Ultra]. In any case, the issue is
that the signal is not driven on an Ultra sampler, so I might decide to add a
pull down to that pin so that its not floating [which would allow the SIMM to be
read (but not written without a modification to EOS) on an Ultra Sampler].
So the things left to do....
1. Create a PCB for the SIMM reader [much much easier than the SIMM itself]
    - necessary to program the micro & CPLD + read ROM SIMMs
2. Compile the CPLD software for the new pin arrangement [trivial]
3. Create Software for the SIMM CPU
4. Create Software for the programmer CPU
Have other stuff to do for now butthe hardest part is done [Yay!]
Re: FLASH Progress Report
2010-10-14 by joe.dalton16
I'm quite new to the forum, new xl7 owner and i'm pretty curious about your thread.
What are you trying to accomplish ?
A usb flash for xl7/mp7 ?
What's the purpose of it ? loading new sound via usb ?
Best regards,
Joe
> etc...
> problem.
2010-10-14 by steve_the_composer
Sounds like wonderful progress on the project!!!!!
Steve
> etc...
> problem.
Re: [xl7] Re: FLASH Progress Report
2010-10-14 by Bruce Manning
Jack,
You are the man. Thanks for your efforts.
Bruce
To: xl7@yahoogroups.com
Sent: Thu, October 14, 2010 5:27:29 AM
Subject: [xl7] Re: FLASH Progress Report
Steve
> etc...
> problem.
>includes
>the
>be
2010-10-14 by Mauricio Balma
thank you Mr MAnning.  I can't wait to use my  own sounds on the command
station.
Sent: Thu, October 14, 2010 8:16:23 AM
Subject: Re: [xl7] Re: FLASH Progress Report
Jack,
Bruce
Steve
> etc...
> problem.
>includes
>the
>be
2010-10-14 by Matt
this is awesome
On Oct 14, 2010 8:08 AM, "Mauricio Balma" <balmaproducer@...> wrote:
thank you Mr MAnning. I can't wait to use my own sounds on the command station.
Jack,
Bruce
From...
2010-10-14 by Geert
damn!! wish I was that knowledgable... keep it up!
> etc...
> problem.
Re: [xl7] FLASH Progress Report [2 Attachments]
2010-10-14 by Ivan Chaparro
your a fucken genius man! i cant wait till this is available. this is gonna change the way i produce. I actually own an asr-x pro and an e-mu 6400 ultra but scsi is such a pain and is not supported with newer apps/pc's. I sequence on my px-7 and trigger samples from my asr-x pro. I think i will primarily use this for new drum sounds into my px-7. keep us posted and keep up the good work man.
etc...
problem.
2010-10-15 by Jack Pratt
Well I relented and put a mini USB-B connector on the side (towards the back of
the P2K module, not sure where this ends up on a command station - I'll have to
open up my XL7 to check). This means that you won't need a special cable to
connect to your computer. [I made room by relegating the debug serial port and
another copy of the USB signals to an edge connector, just like the JTAG ports,
which required that I move the second notch to the opposite side of the board -
diagonal from the 'normal one' - consequently the board is programmed by
rotating it 180 degrees rather than flipping it, and I'll have to debug it in
the programming connector.]
For those not in the know, you can read the threads from earlier this year.
But a quick recap:
- The SIMM has 2 x 1Gb FLASH which means that it has a total of 256MB, allowing
for the equivalent of 7 slot ROMs which have 32MB of Wave ROM and 4 MB of Preset
ROM.
- Since the P2K and Command station can only access 32/4MB per slot, the SIMM
can 'pretend' to be in 1, 2, 3 or 4 slots at the same time and provide wave and
preset information for those slots [you can select the number of slots with DIP
switches]. Of course it the SIMM is pretending to be in a particular slot, you
can't have another SIMM in that slot (or it will cause a conflict).
- The contents of the FLASH can be reprogrammed using the on-SIMM cpu which has
a USB interface
- The contents of the FLASH can also be programmed with a base board (which will
also allow any existing SIMM to be read)
- At some time I would like to write software that will allow the user to
imports various sound formats into an image (and edit some presets, but you
won't be able to hear what they sound like except perhaps on Proteus X or
Emulator X software). So to get the presets that you want [for your own Sounds]
you might need to create the wave ROM, create some presets in user banks
download them via sysex, then edit them into images and reprogram the SIMM.
Tedious, but you don't need an Ultra Sampler that way. The sofwtare should also
allow you to put audition sequences and 'demo songs' directly into the FLASH as
well
- At some time I would like to reverse engineer the OS for a P2K (and later a
command station) so that it can switch between banks [the CPLD supports this
allowing it make use of all seven banks, not just four] program the presets
directly, and possibly allow for some interaction with a PC via the USB
connection.
- The SIMM can be put in AUDITY mode allowing for two banks of 16MB on an Audity
2000.
- The SIMM should act as a single ROM in an Ultra Sampler (and you can select
the bank using DIP switches)
- A DIP switch will allow you to select different banks, but the proteus
software only reads presets immediately after power up so this is only useful
with a power cycle.
Sent: Thu, October 14, 2010 4:31:30 PM
thread.
Best regards,
Joe
2010-10-15 by joe.dalton16
My god :)
This look sooooo great man !
Thanks a lot for the quick recap ;-)
This will open command stations to a new world of possibility.
I just bought a CS recently and i'm so exited to hear about that.
Sooooo glad i joined this forum, thanks for your work i'm sure you'll make tons of happy e-mu owner :)
(Sorry for the poor english, i live in belgium and i'm french speaking)
> But a quick recap:
> ROM.
> a USB interface
> well
> connection.
> 2000.
> with a power cycle.
> From: joe.dalton16 <electric-motion@...>
> Hi,
> thread.
> Best regards,
> Joe
2010-10-15 by Bruce Manning
Jack,
Truly amazing engineering for the Proteus line, not only expanding the memory
but the possibility of importing other formats is phenomenal.
Keep up the great work.
Bruce
Sent: Fri, October 15, 2010 1:29:11 AM
But a quick recap:
ROM.
a USB interface
well
connection.
2000.
with a power cycle.
thread.
Best regards,
Joe
I hope no one has misconceptions.
The P2K series can only access 128MB of wave forms (+16MB preset) at any one
time. The SIMM really just allows you to do that with only one SIMM rather than
four so you don't need to try and buy ROMs from ebay at high prices. Even
if/when the OS is modified to allow you to switch between images you can't
reliably do it while sounds are being generated so you won't really get
'expanded' memory.
Also, because of size constraints (and the fact that I didn't want to use a BGA
package for the first run - harder to debug and almost guarantees that you need
to have a prototype run) the micro only supports USB full speed allowing a
transfer rate around 1MB/second (so it will take up to 40 seconds to write an
image, or approaching 5 minutes to program the entire FLASH. It won't be super
fast!
On the plus side, I'm hoping that the 64-voice modules (which only have two SIMM
sockets soldered in) will support four 'virtual slots'.
Sent: Sat, October 16, 2010 12:22:54 AM
Jack,
Bruce
2010-10-15 by Ian Lamb
Jack:
I value your consideration, efforts, prudence, and vision.
Even with these "limitations," I am very much looking forward to this.
cheers,
Ian
2010-10-16 by Atom Smasher
On Fri, 15 Oct 2010, Ian Lamb wrote:
> Jack:
me too.
my current sampler is a yamaha a4000. when this mod is available, my
orbit-3 chassis will replace it.
         ...atom
  http://atom.smasher.org/
  762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808
 	"Those who make peaceful revolution impossible
 	 will make violent revolution inevitable."
 		-- John F. Kennedy
2010-10-16 by nenad.lonic
Yes, this should be awesome!
--- In xl7@yahoogroups.com, "joe.dalton16" <electric-motion@...> wrote:
> My god :)
> > But a quick recap:
> > ROM.
> > a USB interface
> > well
> > connection.
> > 2000.
> > with a power cycle.
> > From: joe.dalton16 <electric-motion@>
> > Hi,
> > thread.
> > Best regards,
> > Joe
