correction, patterns that go into a multitrack pattern don't have to be the same length or tempo. don't know about cross-pasting different time signatures though
--- In
xl7@yahoogroups.com, "dutchbeats"; wrote:
> the only way to trigger the next pattern in the cs before the end of the current pattern is to select the next pattern either with the jog wheel or trigger buttons, press and hold play and tap stop. this is not on beat though, but good for a s-s-s-sampling effect;)
> another way is to open a blank pattern and cut and past multitrack data into each track from the other patterns. go to one pattern and copy all(or not) tracks to clipboard using the combine function. then go to the empty pattern(to save time save a pattern as a template with all tracks set to multitrack) and paste into a track. do the same with the remaining tracks or how ever many are required.
> now within one pattern you can instantly switch between tracks while keeping tempo. the drawback i guess is each pattern must be the same length/tempo/time signature. although you can copy a track and offset or add to it to correct or embellish. that's also not stopping you from making another multitrack pattern and switching between them etc and so on.
> if you do any live tempo changes you don't have to worry about them being reset when switching patterns since it's all within one pattern.
> --- In
xl7@yahoogroups.com, Bruno Kopias-Czekay wrote:
> > Dnia 27-12-2010 o godz. 06:18 James Ulibarri napisał(a):
> > > you guys rock. i love how the CS will queue up the next pattern trigger by flashing and let it FINISH it's bars before kicking in the next one.
> > I would love it more to see it configurable, like in the rm1x. With side notes, that having only two options: 1/16 and whole measure makes it not so flexible, and having crappy pads (thanks, Yamaha!) would make it completely unmusical.
> > An instant profit: make 8-bars pattern that can be looped and make 1-bar pattern with break, that you can throw into the flow whenever you like. Of course the same way you can extend the "break" pattern to 4 bars, so I consider it fixed.
> > I recall, however, the crazy breakbeat things I was able to create on rm1x in no time. I never tried an external kbd for triggering patterns - had rm1x only for one week (being a proxy for the real owner) and it convinced me to get a pattern based seq. Having already P2K I didn't think a lot about possible options.
> > Bruno
