recall presets in running pattern? tick zero?
2010-12-29 by Atom Smasher
if i have a pattern that automagically assigns the correct presets on the
correct channels; then i change the presets while the pattern is running;
is there a good/quick way to recall the presets saved in the pattern?
thanks...
         ...atom
  ________________________
  http://atom.smasher.org/
  762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808
 	"Everyone thinks of changing the world,
 	 but no one thinks of changing himself."
 		-- Tolstoy
Re: [xl7] recall presets in running pattern? tick zero?
2011-01-10 by Aaron Eppolito
I believe you can queue up the pattern again.  You might have to queue something
else, then requeue the original (before the temp one kicks in).  This may not
work for two reasons: the pattern might just go back to playing itself without
requeueing, or, even if it did, it might use the current settings.
Other things to try:
• revert while playing
• if you can stop, hitting stop 3 times (1st stops, 2nd returns to start, 3rd
replays T0 settings) will restore your settings
trying to think of other ways, but nothing else is coming to me...
-Aaron
----- Original Message ----
To: xl7@yahoogroups.com
Sent: Tue, December 28, 2010 11:07:39 PM
Subject: [xl7] recall presets in running pattern? tick zero?
thanks...
         ...atom
        -- Tolstoy
2011-01-10 by Matt
revert to saved pattern while playing is what you want.
-Aaron
thanks...
...atom
-- Tolstoy
