how do I set arp to same as key range?
2011-01-02 by emuxl7
he110 - I am using controller C-1 to B-2 to trigger only sampler- and want to play xl7(synth) on controller only from C-3 to C-6 I set KEY RANGE in layers and all is fine until I turn arp on- and the keys from C-1 to B-2 play xl7... is there seperate arp range that I miss? thanx for any help.
2011-01-02 by Atom Smasher
> play xl7...
top of pg 255 of the manual (XL7-OpMan-G.pdf).
"Notes inside the range will arpeggiate while notes outside the specified
range will not arpeggiate. Use the Extensions parameters to exceed the
upper boundary of the Key Range (see the information about Extensions
beginning on page 251)."
the pictures shows "MASTER ARPEGGIATOR" but "the preset and master
arpeggiators have the same parameters".
...atom
________________________
http://atom.smasher.org/
762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808
"The enemy is anybody who's going to get you killed,
no matter which side he's on."
-- Joseph Heller, Catch-222011-01-02 by emuxl7
thanx - seems key range for ALL layers does not affect arp range. that is seperate in menu. and I finally found it. --- In xl7@yahoogroups.com, Atom Smasher <atom@...> wrote:
> > On Sun, 2 Jan 2011, emuxl7 wrote: > > > I am using controller C-1 to B-2 to trigger only sampler- and want to > > play xl7(synth) on controller only from C-3 to C-6 I set KEY RANGE in > > layers and all is fine until I turn arp on- and the keys from C-1 to B-2 > > play xl7... > > > > is there seperate arp range that I miss? > ======================= > > top of pg 255 of the manual (XL7-OpMan-G.pdf). > > "Notes inside the range will arpeggiate while notes outside the specified > range will not arpeggiate. Use the Extensions parameters to exceed the > upper boundary of the Key Range (see the information about Extensions > beginning on page 251)." > > the pictures shows "MASTER ARPEGGIATOR" but "the preset and master > arpeggiators have the same parameters". > > > -- > ...atom > > ________________________ > http://atom.smasher.org/ > 762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808 > ------------------------------------------------- > > "The enemy is anybody who's going to get you killed, > no matter which side he's on." > -- Joseph Heller, Catch-22 >
