> I have tried out disabling the USB2 support in the BIOS of the PC
> (I think then it must work as a USB1 or 1.1 port) and still no
> communication in the Eloader, (yes, XP SP3).
> Prodatum and Proteum (other Java based softwares) can't see the USB MIDI device either.
> At this point I give up connecting directly the CS's USB port to this PC.
> (As I remember there was no problem with my previous PC -Windows2000/USB1
> ports... just to confirm the USB2 port and the newer OS issue.)
> Thanks for the intermediate device tip, I'm affraid I have to keep using
> the standard MIDI ports, I have no any instrument/controller with USB
> host ports.
> Andrew
> ps.: One more thing (If anyone may continue the investigation):
> during the installation of the EMU drivers,there were two device recognized:
> E-mu USB device, Interface 0 and
> E-mu USB device, Interface 1.
> I don't know it means anything at all, but now I can see only
> the interface 0 in the connected USB devices window.
> Maybe that inactive interface 1 could casue the problem?
> On Sun, 23 Jan 2011, Asukaya Bailey wrote:
> > I had this issue through many versions of Xp. It worked with XP Service pack one
> > and with a USB 1 interface, along with the Midi In and Out connected to a 1x1
> > USb midi device. I suggest XP sp3 if that is what your using and an interface
> > that connects to the computer via USb for MIDI. Maschine, A Midi Keyboard with
> > USB in/out, along with your USB connect to the CS should help the situation show
> > up in the CS editor. Also I've head that USb 1 hub can help in addition. As your
> > issue was the midi section connect any interface or sound card your using for
> > external midi in/out to the cs, as well as having the unit connected should make
> > a difference.
> > Kayaone - Luminous Velocity
> > Asukaya Bailey - CEO
> > Luminous Velocity Productions
> > Brooklyn, NY 11203
> > 347.712.7738
> > www.luminousvelocity.net
> > kaya.bailey@...
> > kayaone@...
> > luminousvelocity@...
