Pointing sub out cc 79 to individual layers
2011-02-28 by Matt
How do I point cc 79 to individual layers? Is this possible?
On Feb 27, 2011 8:54 PM, "Matt" <somatt@...> wrote:
thank you!! This is awesome
>; On Feb 27, 2011 5:56 PM, "Atom Smasher" <atom@...> wrote:
> On Sun, 27 Feb 2011, Matt wrote:
> So I remembered someone typing in this list about the sends an...
> do this - http://launch.dir.groups.yahoo.com/group/xl7/message/21491
> > Now I got sub out 1 with turned up gain and bass on the mixer and sounds
> just as good as esi....
> my ex-wife is a big fan of hardcore techno. she isn't into gear at all, ...
> > I guess I took gas-x cuz no more GAS. Now all I need is the cs. Maybe
> I should get an insuran...
> here's the weird thing for me... i have a lot of synths; K5K, fs1r,...
Re: [xl7] Pointing sub out cc 79 to individual layers
2011-02-28 by Atom Smasher
no. but... if you're doing what i do, using at as six mono outputs, you
can do something like this: route a preset to (eg) send2->sub1. then you
can *pan* the layers independently and route them to different outboard
fx. that would give you a preset with layers divided between two outputs.
of course you can also use the main stereo outputs with onboard effects
and then use the sub outs as four mono sends with outboard fx... that's
just one way to slice-n-dice it. there's a lot of flexibility with the
outputs.
bear in mind that "pan" is a summing node: "All the modulation inputs on
XL-7 are summing nodes. This means that you can connect as many modulation
sources as you want to an input (such as Pitch or AmpVol). Modulation
sources are simply added algebraically -- connecting two knobs one set to
-100 and the other set to +100 yields a net value of zero."
         ...atom
  ________________________
  http://atom.smasher.org/
  762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808
 	Quidquid latine dictum sit, altum viditur.
 	(Whatever is said in Latin sounds profound.)
OT: EX-800
2011-03-06 by steve_the_composer
After years of inactivity, my EX-800 came out of mothballs and I replaced the long-dead battery. Inspired by success, I searched for mods which I had discovered at a few years ago and re-found the Moog Slayer mod (and others). (I thought your name sounded familiar--I just didn't remember from where.)
Steve
