> Hi,
> As Steve points-out, the preset layers have no samples assigned. The reason was to ensure compatibility between different ROMs.
> You will need to select your own samples for the two layers as stated in the original post.
> If you are still having issues I will provide a prodatum version - but again you will need to select your own samples for each layer.
> good luck
> --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@> wrote:
> > I am having trouble parsing your post. I have put in some [extra words] and punctuation to try to make sense of it. See below.
> > --- In xl7@yahoogroups.com, "Akrons Secret" <akronbestkeptsecret@> wrote:
> > > Hello all [I have a] couple [of] questions. I have the pure phatt,xl,cmpsr,& beat garden roms. I tried to upload the Jh sine kick with proteum & emu light cmi with prodatum. [B]oth appeared to work. I have [the] 2 patches [showing] with the right name but no sound [comes] out the main. [A]re the[y] routed to sub out's?
> > First, you can check this by looking at MIX OUTPUT menu when you select preset edit. Second, you can check to see what ROM INSTRUMENT the presets use also. If 000: None appears, or if there are question marks (???) or it says something like not instld, you need to assign the preset some ROM INSTRUMENTS.
> > With Jh sine kick, you need to assign sine waves based on whichever ROMS you have. That's how the preset was designed. It is really a template. (Please see the description posted about that preset.)
> > As for emu light cmi, I am not sure which ROM that was designed for, but if you don't have the right ROM, you can probably play around with it by selecting any ROM INSTUMENT from what you do have.
> > > Also I've seen the pop presets for the cmpsr rom what's the give & take on that?
> > I am not sure about this. I know there are several versions of the composer ROM. Maybe the pop presets are the ones from the keyboard version, but I am not sure.
> > Hope this helps.
> > Steve
