HELP??
HELP??
2001-09-17 by Urth
Howdy folks,
    Has anyone else experienced problems switching back to song mode after
jumping into pattern mode to do a loop?  Most of the time the song picks up
at some random measure that is usually within 10 or 15 measures of where it
left off... which, of course, throws the whole song sequence off.  The
ability to switch seamlessly between song & pattern mode is THE reason I
bought this machine.. anyone know of a way to remedy this?  (Still wonderin'
where to find the SysEx info, too)
    Brach
Re: [xl7] HELP??
2001-09-18 by Aaron Eppolito
Song -> Pattern -> Song should work as follows:
When you switch from song mode to pattern mode, the currently playing pattern
will continue to loop indefinitely.  When you switch back to song mode, the
pattern will continue to play *to its loop point* at which point it will loop
and the song will pick up from where that pattern *had started*.
This means that your song will not pick up where it left off, but rather at the
point at which that pattern had stopped.  For example, in the song that
contains:
Bar 01 - Pattern A
Bar 17 - Pattern B
Bar 33 - Pattern C
if you switch from song to pattern at bar 20, Pattern B will loop continuously.
When you switch back, Pattern B will run till its loop point (up to 16 bars
later, depending on when you switched).  Then, it will loop and the song will
pickup at bar 17 (not 20!).  This is done to insure the most seamless transition
(you wouldn't want your pattern to suddenly jump forward 3 bars would you?)...
-Aaron
Urth wrote:
> Howdy folks,
> Thanks,
>     Brach
> To unsubscribe from this group, send an email to:
> xl7-unsubscribe@yahoogroups.com
Re: HELP?? Song/Pattern Mode Switch Defect
2001-09-19 by egroups@urth.ws
I don't know whether this particular machine is defective or if
this is a software problem, but the song/pattern/song mode switching
doesn't work correctly.  Sometimes it works as you described... At
least half of the time, though, it jumps to some random measure after
it's finsihed the current pattern loop.  For instance, if this is my
form:
Bar 01 - Pattern A
Bar 05 - Pattern B
Bar 09 - Pattern C
Bar 13 - Pattern D
Bar 17 - ---STOP---
   I switch to pattern mode at bar 07 & let it loop for a while..
when I switch back to song mode it finishes the current loop & then
half the time it just goes randomly to any subsequent measure (lets
say bar 20).  As in this case, it often jumps beyond the end of the
sequence & then just continues to endlessly loop the pattern that was
looping in pattern mode (pattern B) because there are no more pattern
changes in the sequence (obviously), and there is no stop command,
since it has already bypassed that measure & skipped over the entire
remainder of the song form!
  Sometimes, it will return to some bar within the original song mode
loop, but not change into the next pattern when that bar comes
around.. (for example, instead of jumping to bar 20 it might go to
bar 08 then stay on that same pattern (B) on thru bar 09 until it
reaches the next change into pattern D at bar 13.. skipping pattern C
completely!)
   Has anyone used this function extensively and NOT had these kind
of problems?  I was planning to use this unit in live performance,
but if it continues to do this, it will be useless to me (plus, I
can't seem to find any other unit that will allow realtime change
from song to pattern mode & back)... any help would be greatly
appreciated...
      Brach
playing pattern
mode, the
will loop
rather at the
that
> contains:
> Bar 01 - Pattern A
> Bar 17 - Pattern B
> Bar 33 - Pattern C
continuously.
16 bars
song will
seamless transition
would you?)...
> -Aaron
