midi clock not transmitting?
2011-09-15 by magpieindustries
 I have an electronic drumkit acting as midi master clock. Its connected to my XL7 which has the base tempo set to 0 (it says EXT). I can press start/stop on the drumkit and change the tempo, and the XL7 reacts fine.
The problems begin when I connect something else to the midi OUTs on the XL7. I have set Transmit MIDI CLock on A & B Out, but it does not seem to be transmitting any clock (it is transmitting note on/off quite ok). If I use the XL7 to merge the midi in to midi out A (or B), then I can send the start/stop messages through the xl7, but the clock messages are not arriving!!
If I connect the drumkit to the slave gear, it works fine, so the messages are disappearing inside the xl7, or the cables.. With this setup, if I change the base tempo to a positive number, so the XL7 is then the master, then the play and tempo controls on the xl7 are being transmitted.
I was pretty sure this has worked before, but I've been rearranging some gear and changes around some cables. Any suggestions for something that I may have missed?
/ Niall
Re: [xl7] midi clock not transmitting?
2011-09-15 by Greg Waltzer
For some reason, the XL7 does not retransmit received midi clock. It
only sends out midi clock when it's the source.
Might be better to use the XL7 as master.
magpieindustries wrote:
> Hi,
> reacts fine.
> transmitted.
> / Niall
Re: midi clock not transmitting?
2011-09-16 by magpieindustries
Argh! Oh no, that is very bad news :(
Im trying to add another drum module and it too does not retransmit midi clock. It's starting to look like I can't get my stuff connected no matter what way I arrange it.
/ Niall
> > Hi,
> > reacts fine.
> > transmitted.
> > / Niall
Re: [xl7] Re: midi clock not transmitting?
2011-09-16 by Bruno
2011/9/16 magpieindustries <dach@...>:
I'm afraid that the majority of instruments does not retransmit the
clock. You need a MIDI interface that can have its routing configured
for a standalone mode - e.g. eMagic Unitor8, since it actually can do
it, as long as the instrument sending MIDI clock sends SongStart/Stop
(my Novation KS5 does not, it transmits clock though, but Unitor was
not accepting it).
Bruno
2011-09-16 by Greg Waltzer
You can probably work it out with a 2x2 midi merge box.
> / Niall
> --- In xl7@yahoogroups.com <mailto:xl7%40yahoogroups.com>, Greg
Thanks for the tip, but I only have hardware in my studio so a pc/mac midi port thing isn't going to help. I'm hoping that something like the Midi Solutions Quadra Merge will do the job. These little midi merge boxes will hopefully pass the clock signal, but I will make sure to be certain of it before buying. Thanks.
> not accepting it).
> Bruno
Can you recommend a specific product which is known to pass the clock and start/stop messages through? I thought any 'merge' device would do it, but now I'm not so sure.
/ Niall
> > / Niall
2011-09-16 by Scott Solmonson
Hmm- I've used a midi merge 2x box in the past and it creates a
noticeable transmission delay.
I wanted to have a sequencer and a controller hitting the same chain,
and while this worked, the sequencer's drums were audibly off-time
with the merger in place. Perhaps newer tech is better but I don't
know.
Regardless, they're not meant to carry clock signal, and while my
first suggestion would be to rethink your entire chain to eliminate
the need for clock passing, if you must absolutely have concise clock
going to several devices at once I think the only way to do it is to
have a simultaneous-out MIDI-8x interface or something. There will be
clock slew from the computer to the interface, but on the way out it
should be clean. But you don't have a computer in the chain... neither
do I :)
That said, maybe I missed the rest of the thread, but the command
stations have two midi outs, which should usually be enough clock for
any scenario. I'll go back and read the thread to see if you've
descibed your setup but if you haven't, please do so, as well as what
you're trying to do with it.
Cheers-
-SS
>> not accepting it).
>> Bruno
NUNQUAM NON PARATUS
2011-09-16 by Bruno
Apart from Unitor8 I recall that BiPort 2x4 from midiman was able to
do this. While both those devices are in theory PC/Mac midi
interfaces, they also work in standalone mode. For Unitor in such case
you only need a PC to set up the patches, and then you're free to go.
BiPort has fixed routing, no configuration is possible.
Right now you can get Unitor8 Mark I for peanuts (75$ or even less);
the only drawback is that you need an USB - serial port adapter for it
AND a PC (Mac won't do), but only to configure it. Unitor8 Mark II has
the USB connection, but is a bit more pricey. I own both and can
really recommend them. And no, I'm not going to sell them :-)
HTH,
Bruno
Ok got it-
You can only have one authoritative clock- think of it as a heartbeat.
Lots of shit has an inbuilt sequencer, like your drumkit, but you have
to decide which of your devices is "best" at that.
I would not have the drumkit acting as the main midi clock source as
it's mostly a live-input device, whereas your XL7 has a very
sophisticated sequencer and two outs- it should be the master clock,
and whatever else you've got downstream should be treated as a sound
module and sequenced from it.
-SS
On Thu, Sep 15, 2011 at 12:43 PM, magpieindustries <dach@...> wrote:
> Hi,
> / Niall
NUNQUAM NON PARATUS
The midi solutions boxes will pass clock. I use them in the studio and
haven't had any problems with delays. If you are seeing delay, it's
probably due to the amount of midi data being transmitted (such as pitch
bend, sysex, active sensing, lots of CCs), as the midi protocol has
unfortunately not much bandwidth.
I think in general any hardware merge box should retransmit clock, as do
"thru" ports, if they adhere to the midi spec. The ports on the XL7 are
technically not "thru" but "out".
> --- In xl7@yahoogroups.com <mailto:xl7%40yahoogroups.com>, Bruno
> > not accepting it).
> > Bruno
2011-09-16 by steve_the_composer
If you don't mind old gear, any dumb midi thru-box should do it--such as the ancient Casio TB-1; or you could build your own (though the parts might cost a tad more than a commercial vintage thru-box.
Another option would be a midi router. Before usb, MOTU made some parallel port midi routers which on the second-hand market have become quite cheap because of the disapperance of parallel ports.
With software and a parallel port, you can program (route and filter) 8 midi ins and 8 midi outs on the MOTU midi express, to take one example. However there are also 8 fatory setups, one of which will send the midi out on all inputs to all outputs. Thus you could take the midi clock, put it on one input and send it to up to 8 outputs.
So, for example, you could transmit midi clock only from an XL-7 and send it to 8 different drum machines with either the Casio or the MOTU. I am sure there must be other gear you could use. These are just some examples.
> / Niall
> > > / Niall
Footnote:
As of this moment I see 3 TB-1s on ebay. One is actively being bid on (3 bids so far and it is in the $20 range.) For the wall wart and a TB-1 in good working condition, I'd say this is fair market value. In my opinion the one listed for $99 and the one listed for $175 are seriously overproced for what you'd be getting.
BTW: One description reads as follows: "This particular unit is in decent cosmetic condition, however the power jack is a little loose. . . . Due to the issue with the power supply jack, this is an AS-IS auction."
I had what sounds like the same problem with a radio shack power supply and the TB-1 because the "standard" power adapter plug is not an exact match. The purchaser could replace the plug, use 6 1.5 volt batteries (assuming the unit came with the battery holder, etc. I just backed the plug a little bit out and it made good contact.
It does bother me when the seller says "It has two inputs and three outputs." It should have 2 inputs and 8 outputs. If I were shopping, Iad ask about that.
2011-09-18 by magpieindustries
Ok, I'll try and describe what I have an what I want to do :)  Long post warning!
I have an XL7, a TD12 drumkit, and an SPD-30 drumpad. I also have a couple of other things but they are just midi in->thru and are rather simple, so I'll ignore them from now. I have an access virus kb synth (keyboard version).
My goal is to have the xl7 sequencing the virus. The virus shall play basslines, and I will play drums over this. I do want to record the drums too though, as this certainly helps when working on the basslines, or on the overal sound production.
My studio space is extremely restricted, so I have the XL7 and virus set up directly behind my drum throne, and I turn around 180 to work with those. The TD12 (which I've been using as master clock) is located on the drum rack, and it is very convenient to adjust the tempo there (something I do all the time while practicing).
I've tried a couple of different midi routings but all of them seem flawed in some critical way. Note that all devices produce midi, and its preferred that all devices receive clock (to sync up internal fx and looping capabilities).
The TD12 has a midi IN/OUT and a soft thru. It passes everything it receives.
The SPD30 also has only an in/out and soft thru, and it does not pass the clock (it will pass the midi notes).
The virus has an in,out,thru. And a selectable soft merge of in->out.
I have the SPD30 placed after the TD12 as I want to hit my td12, generating midi, which is passed to the spd30. It may be possible to have the spd30 before the td12, and pass midi all the way through the chain, but I haven't gotten that far yet.
My first attempt looked like this
t12 -> spd30 -> XL-7 -> virus -> td12.
This works ok for the midi notes, and i can record both drums and virus without swapping the IN cables (not a dealbreaker but nice to have). The problem is the spd30 drops the clock, so the xl7 doesnt sync with the tempo changes.
Next, I tried:
xl7 -> virus -> td12 -> spd30 -> xl7.
If I turn on all the soft thru's, this works for the clock, but when I start recording on the xl7 with REC+ and let it loop around, it starts playing back the midi, which passes through the chain and gets recorded again. This is causing flamming and phasing effects as the notes get built up.
Using REPL mode, it worked better as the xl7 automatically drops out of record mode, but this has a disadvantage that i have to stop the sequencer and select REPL every time (it keeps defaulting to REC+) and this quickly became rather tiresome.
Suggestions would be really welcome!!!
/ Niall
> know.
> do I :)
> Cheers-
> -SS
> > --- In xl7@yahoogroups.com, Bruno <brunorc@> wrote:
> >> 2011/9/16 magpieindustries <dach@>:
> >> not accepting it).
> >> Bruno
> > Yahoo! Groups Links
> NUNQUAM NON PARATUS
2011-09-18 by Bruno
Hi Niall,
2011/9/18 magpieindustries <dach@...>:
If I understand it well, what you want is not to clock everything from
TD12, but rather use TD12 to control the tempo. I never used TD12, but
is it possible to somehow make it the source of two MIDI CC
controllers which would control the Tempo of the MIDI Clock in XL7?
See page 145 of manual revision G, or press "Controllers" button on
your XL7 and scroll to "Tempo Controller" screen.
For the love of Cthulhu, how do I hate it... anyone knows a solution
for this one?
Bruno
Thanks for the tip on tempo controllers, if I can't get a knob on the TD12 to do it I probably can find some other knob within reach. This is really useful, thanks!
Strangely enough, I've now connected things:
td12(master) -> virus -> xl7 -> spd30 -> td12
The note doubling/phasing problem has disappeared. Maybe there was a delay in the chain when it was set up the other way? Now I can hit Record and play drums, and when it loops, I stop playing drums and I hear the playback. I can also overdub like this, so I think I'm getting somewhere at last...
/ Niall
> Hi Niall,
> for this one?
> Bruno
