P2K_MASTER_FX.txt ?
P2K_MASTER_FX.txt ?
2011-11-11 by D F Tweedie
I found this patch script file at the P2K group: "P2K_MASTER_FX.txt "
Though is is for the P2K, shouldn't it work equally well with a CS? Aren't the FX parameters identical?
The only thing I noticed in the script that seemed specific to the the P2K was a parameter:
UNIQID: 32512607
Has anyone using Cubase tried this on the CS? Do the different CS have separate unique IDs from the P2K?
And if so, what are they ... or where do you find the info for your unit (PK-7 for me)?
Thanks
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
