Upgrade to OS 2.0: download fail
2012-02-27 by shakerz25
Trying to upgrade an MP-7 from 1.18 to 2.0.  Using a Windows XP PC this time (gave up on using MAC OS 9 Classic--can't open e-loader).
Downloaded and installed e-loader, and it looks functional.  Downloaded the 2.0 dli file from the E-Mu site as well.
But I can't get a complete download of OS 2.0 to the MP-7 before the download fails.
The download request from the MP-7 works, I start the download from e-loader (it says the complete download is 557331 bytes), but it fails every time, at different stages of download.
Error message on PC says download filed.  Error message on the MP-7:  "Error Downloading MIDI:  Wrong Length."
Tried many times; the failure occurs at different points in the download:
1904 bytes
9072 bytes
43680 bytes
100800 bytes
3584 bytes
52976 bytes
18592 bytes
55216 bytes
11872 bytes
etc.
Is there some MIDI setting on the MP-7 that has to be set?  I've tried varying the MIDI Sysex Packet delay, for example (it can be set from 0 milliseconds to 8000).  I've also tried changing the Sysex ID from 0 to 1.  Download fails the same way every time, at different points in the download.
Since the e-loader software seems to work, and at least part of the download works, it looks like the problem is in the MP-7--but this one is in pretty good shape.  Any ideas...?  How do people get this to WORK...?
Re: [xl7] Upgrade to OS 2.0: download fail
2012-02-27 by Bruno
2012/2/27 shakerz25 <shakerz25@...>:
Are you uploading thru the USB interface or MIDI interface?
Re: Upgrade to OS 2.0: download fail
Not using the USB connector on the MP-7; my understanding is that does NOT work for upgrading OS, you have to use the MIDI connectors on the MP-7.
I'm using a USB MIDI (U2 Midi) interface.  It is recognized by the PC.  MIDI In & Out connections to the MP-7 are correct, with USB end of cable going to USB port on the PC (front).  Since the download partially happens, I think the USB MIDI interface and connection are OK.  Thanks!
Re: [xl7] Re: Upgrade to OS 2.0: download fail
2012-02-27 by Bruno
It is possible that MIDI interface chokes on the heavy SysEx data,
which apparently cannot be slowed down with "packet delay" parameter.
Can you try a different MIDI interface? I recall upgrading the OS thru
my eMagic Unitor8 (and before, upgrading P2K few times thru the
Midiman BiPort on serial port) and it worked like a charm.
If you don't have (access to) any other MIDI interface, maybe you can
give your location and one of list members living nearby can help you.
If you're close to Amsterdam, Netherlands, I can be that guy ;-)
Bruno
2012-02-28 by steve_the_composer
I and others have written about E-Mu usb drivers on XP. I had the hardest time until either SP2 or SP3.  I think Windows changes how composite usb devices were handled. I assume you have SP3.
That being said, if you don't have the usb drivers installed, that shouldn't be your problem.
I do believe several people had problems with specific usb midi interfaces. Possibly some ate sysex, I think.  I would look at the midi monitor in e-loader and see what is going is going on in terms of the communication (if you can do that while in OS install mode--not sure about that).
I will try to carve out some time to see if I can find related discussions in the archives (unless you already checked there).
Steve
> Bruno
2012-02-29 by shakerz25
Thanks; I have checked the archives a bit.  I'll try to find another MIDI interface, and/or, as another forum member suggested, try to upload the command prep software first (even though I have OS 1.18 in the MP-7).  Thanks...
> Steve
> --- In xl7@yahoogroups.com, Bruno <brunorc@> wrote:
> > 2012/2/27 shakerz25 <shakerz25@>:
> > Bruno
2012-03-01 by steve_the_composer
I think my P2500 started with OS1.18. Not sure if that required the command prep. Better double check before running command prep--because: http://launch.groups.yahoo.com/group/xl7/message/16823
Steve
> > Steve
> > > Bruno
Re: Upgrade to OS 2.0: download fail (HOW TO SUCCEED!)
2012-03-25 by adrian.gay@btinternet.com
I just had the same problem trying to upgrade an MP-7 that had OS 1.31. The solution is to first download the bootloader "commandprep10.dli", even though the E-loader documentation says this is unnecessary. Then download the version 2.0 OS.
All working fine now for me.
> 1904 bytes
> 9072 bytes
> 43680 bytes
> 100800 bytes
> 3584 bytes
> 52976 bytes
> 18592 bytes
> 55216 bytes
> 11872 bytes
> etc.
vintage rom
2013-01-07 by Greg Waltzer
I have a spare vintage rom for sale - it's one of the hardest to find!
$250 plus shipping.
The Vintage Collection Expansion ROM is a 32 MB collection of classic
keyboard sounds from the '60's, '70's and '80's. With an extensive
complement of tonewheel organs, suitcase pianos, analog and digital
synthesizers, Vintage Collection is an indispensable tool for musicians
playing almost any kind of music, from classic rock and blues to the
latest in dance music productions. These keyboard sounds have a timeless
appeal that fits almost every genre of music. Vintage Colletion offers
you over thirty classic keyboards in a single expansion ROM. And every
preset is set up to control a host of synthesis and filter parameters
via the real-time controllers found on every E-MU Module, Command
Stations & Keyboard. Put three decades of authentic keyboard sounds to
work in your instrument today and hear why Vintage Collection is an
instant classic.
The Vintage ROM is Compatible with All Emu Proteus 2000 Series Instruments:
*Sound Modules: Proteus 1000/2000/2500, Xtreme Lead-1 (XL-1), Mo'Phatt,
Virtuoso 2000, Orbit 3, Vintage Pro, B-3, Planet Earth, plus all Turbo
Models
*Keyboards: Ensoniq Halo, MK-6, PK-6, XK-6, & Vintage Keys
*Command Stations: MP-7, PX-7, & XL-7
Re: [p2k] vintage rom
2013-01-21 by Greg Waltzer
now listed on ebay:
http://www.ebay.com/itm/321059784005?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
> $250 plus shipping.
> instant classic.
> Instruments:
> Models
emu users get-together
2013-01-28 by Greg Waltzer
Anyone interested in a user group meeting for emu command station/proteus?
It would be during the electro-music festival, Sept 6-8 in Huguenot, NY.
Re: [xl7] emu users get-together
2013-01-28 by gary higgins
I would, for me at least-it's on the east coast-nice idea! Would be great seeing how others work and what they end up with-I'm pretty sure we each approach it in a unique way.
To: p2k@yahoogroups.com, xl7@yahoogroups.com
Sent: Mon, 28 Jan 2013 13:37:01 -0000 (UTC)
Subject: [xl7] emu users get-together
Re: emu users get-together
2013-01-31 by just john
Hey, that looks like only 70 miles from me, as the Google flies!
(Tho I'm afraid I have about ONE useful tip to share, when it comes to the XL-7, and that's this:  Set up a one-voiced patch on one channel and feed a few different pattern tracks into it.  Then have fun muting and unmuting the patterns as they play.)
I see the website is still about last year's iteration:  http://event.electro-music.com/
The schedule looks pretty structured.  And I'm surprised at the lack of headphones in the photos.  I was imagining this would be ideal for JamHub-style playing, with each person being able to mix the players to their own satisfaction.
How much are tickets, etc?
> From: Greg Waltzer
2013-02-02 by Jason Budris
Do you still have this?
--- In xl7@yahoogroups.com, Greg Waltzer  wrote:
> now listed on ebay:
> > $250 plus shipping.
> > instant classic.
> > Instruments:
> > Models
