More SIMM problems - Protozoa ROM causing distortion on other ROMs
2012-05-10 by retroillumination
Hi folks,
I was just reading the recent ROM list / SIMM issues post, and I wondered if anyone could shed some light on this problem.
Using an XL-7 with os 2.00. Pressing the audition button shows these ROM ID's:
MSB:O14 Xtreme lead - displays 'XL-7'
MSB:005 Protozoa - 'P/123'
MSB:017 Composer - 'PROM1'
MSB:065 Techno Synth CY - 'TeCnO'
I can get the checksums from those ROMs later if that's any help.
All ROMs pass the diagnostic. The problem is - the sounds of the Protozoa cause a terrible distortion with some of the sounds of the other ROMs. The Protozoa sounds fine on its own. The other 3 roms play just fine together.
It's a shame because the Protozoa is full of great sounds.
Even when the individual track volume levels are turned right down, this distortion kicks in. When you bring in a Protozoa sound, it  plays, but it turns the sound from the other ROMs into a very extreme type of distortion.
Has anyone had any similar experiences, or any ideas?
I did once have a Composer ROM that failed its diagnostic with a 'bad block' message. This ROM used to make crackling noises, kind of very similar to a scratched vinyl, on its drum presets. It was quite subtle. But this with the Protozoa is far from subtle!
Thanks!
Matt
Re: [xl7] More SIMM problems - Protozoa ROM causing distortion on other ROMs
2012-05-10 by Bruno
Hi Matt,
2012/5/10 retroillumination <retroillumination@...>:
I have XL-7 with the same OS, Protozoa & Composer, with MROM & XROM
though (the "later" versions of MP-7/XL-7 ROMs, respectively). I will
try to create some basic presets to see if the same thing happens.
Bruno
Re: More SIMM problems - Protozoa ROM causing distortion on other ROMs
Hey Bruno,
Thank you! This happens with the standard presets anyway - I will try to get an example of two presets that don't play well together, one from the Composer ROM and one from Protozoa.
Thanks for looking into this!
Matt
--- In xl7@yahoogroups.com, Bruno <brunorc@...> wrote:
> Hi Matt,
> Bruno
