PSU repair stuff
PSU repair stuff
2012-05-14 by rogers t
If you bother to do any work on the psu, I highly recommend replacing the electrolytic capacitors.  Mine had leaky caps which actually caused corrosion on the drum pad circuit board.  I've also had leaky caps on a P2K, but there's more risk of leaking electrolyte damaging stuff in the xx7 boxes than in the rack units.
At any rate, go ahead and swap out the electrolytics if you're doing psu repair anyway.  THe 10 extra bucks you spend on parts now might save you a whole lot of grief down the line.
Tom
