How to add another event under pattern edit event
2012-06-21 by Matt
Maybe I am totally missing something simple but I cant figure out how to make a second event in a track.
Under pattern edit event track 15
The first event says no events in track, so I change it to the event I want and I have the first event.
Now how do I create the second?
Thanks!
Matt
Re: How to add another event under pattern edit event
2012-06-22 by steve_the_composer
I am not at my P2500 right now, but isn't it the repeat button that will insert a new event into a track?  Give that a try and if it doesn't work, I will see what it should be.
Steve
> Thanks!
> Matt
2012-06-23 by steve_the_composer
Yup--that's it, but you have to advance the bar:beat:tick counter since you cannot have more than one event at the same tick (IIRC).
Hope this helps.
Steve
> Steve
> > Thanks!
> > Matt
Re: [xl7] Re: How to add another event under pattern edit event
2012-06-25 by Matt
THANK YOU SO MUCH
On Fri, Jun 22, 2012 at 6:14 PM, steve_the_composer <smw-mail@...> wrote:
Yup--that9;s it, but you have to advance the bar:beat:tick counter since you cannot have more than one event at the same tick (IIRC).
Hope this helps.
Steve
> Steve
> > Thanks!
> >; Matt
