presets change
presets change
2002-04-01 by ph.demoor@free.fr
Hello , sorry to bother you but I could'nt find any answer ...:
I want to insert p.changes for different presets in a same track (
channel )in Edit pattern I go to the Event screen I push repeat to
insert different prog. : No1 on bar 1 ;8 on bar 3 for example ; (and I
did check before with the audition button to put the correct msb and
lsb ) so everything is kept in memory but nothing happens !
Help !!  ( I spend hours trying before writing this )
Re: [xl7] presets change
2002-04-01 by erik_magrini@Baxter.com
You need to change the location immediately after pressing Repeat, as you
can't have two events at the exact same time.  So, press Repeat, then
scroll over to the location field and move it forward or backward by one
tick.
rEalm
ph.demoor@...
04/01/02 08:29 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] presets change
