> I hear it mainly on kick samples.
> --- In xl7@yahoogroups.com, Alwyn wrote:
> > Do you get the same delay using different samples/patches?
> > On 10/01/2013 6:07 PM, "johnnie5917" wrote:
> > > Oh dear. I had dusted off my XL7 and was starting to have quite a lot of
> > > fun thinking I would go back to using a hardware sequencer and do a couple
> > > of tracks with it. I had been reading about how the timing on these things
> > > was to die for compared to software sequencers etc.
> > > Back to Ableton, Logic and Reason I suppose.
> > > --- In xl7@yahoogroups.com, "nikitsanpsix" wrote:
> > > > Yes!!! exactly what I`m talking about! Have you any solution for this?
> > > > --- In xl7@yahoogroups.com, "steve_the_composer" wrote:
> > > > > Hmmmm. now that you mention phasing, I am remembering something I
> > > stumbled onto a few years ago. I turns off all FX and anything that would
> > > cause minute delays or pitch shifts, chorus, flange, etc. I repeatedly hit
> > > a note and found that the timbre of the same note played one after another
> > > was different, like there was an unexplained phase differential. I don't
> > > remember much more of my experiments or if I ever tracked the cause down. I
> > > want to say that with each keypress, depending on what the processor was
> > > doing, there was a miniscule phase difference.
> > > > > Not sure if this is what you are talking about; not sure how much of
> > > this I am remembering correctly. I will try to search the archives.
> > > > > Steve
> > > > > > No I have it even if ie track1 - kick sample (main out), track2 -
> > > same kick sample (main out). In result i have some phasing, and flicking
> > > sound on output.
> > > > > > when i route track2 on sub out 1 for compressing and return it to my
> > > MP7 there is same phasing issue and flick on begin of sample.
> > > > > > > So you are seeing some timing difference between the Sub Output
> > > and the
> > > > > > > Main Output?
> > > > > > > On 9 January 2013 16:25, nikitsanpsix wrote:
> > > > > > > > nobody?
> > > > > > > > > I have psoted some time ago about routing mp7 to external
> > > compressor for
> > > > > > > > parallel NY style compression... I have my answer, and thanks to
> > > all guys
> > > > > > > > who helps me .
> > > > > > > > > And now I have another trouble with parralel compression...
> > > > > > > > > I have properly conected and routed my outbord compressor to
> > > sub 1 and
> > > > > > > > all is working, but there are small differences above few
> > > milliseconds with
> > > > > > > > clean and processed signal. It`s sounds not good (flickering in
> > > start). To
> > > > > > > > exclude my compressor latency i try simply make two idetical
> > > tracks with
> > > > > > > > one kick sound preset (without any fx at all), and i have this
> > > latency
> > > > > > > > again.
> > > > > > > > > Any body can try this, two identical tracks sounds with
> > > latency!!!!!
> > > > > > > > > why? and how to correct this issue????
