XL7: save midi settings?
2013-03-18 by raabje
Hello group,
A new XL7 owner here. Still bussy figuring out a lot of things.
I want the XL7 to sequence external gear, track 1 to 7, and the rest 8 to 16 to internal patches. I choose pattern 127, factory setting patch (?)or something, so the engine makes no sound when I hit the pads.
I can make alle the settings, everythings works like it should (lot of small settings, patch change yes/no, rechanelize input for external midi keys, etc).
Then I save the pattern, and de multi setup. When I power down and start up again, alle the settings are lost? It's not saved in the patter, and not in de the multi setup?
I guess I miss something.
Any help?
bye,
Jeroen
Re: XL7: save midi settings?
I might have the answer:
http://launch.groups.yahoo.com/group/xl7/message/19585
The pattern with my midi settings was more or less empty. Changing midi settings for empty tracks is not saved in the pattern. So I have to fill track 1 to 7 with some dummy CC value and save it as a pattern. This pattern is a preset for other patterns.
I wonder what will happen to other (global) midi settings, will try tonight.
--- In xl7@yahoogroups.com, "raabje" <raabje@...> wrote:
> Hello group,
> Any help?
> bye,
> Jeroen
Re: [xl7] Re: XL7: save midi settings?
2013-03-18 by Matt
Turn midi off for 1-8.
--- In xl7@yahoogroups.com, "raabje" wrote:
> Hello group,
> Any help?
> bye,
> Jeroen
2013-03-18 by steve_the_composer
You got it--gotta have dummy data on each track you want to retain channel assignments for, otherwise, seeing an empty track, the channel assignment resets. Tip: If you put your track template at 000^0, it will be right there when you power up.
Steve
> --- In xl7@yahoogroups.com, "raabje" <raabje@> wrote:
> > Hello group,
> > Any help?
> > bye,
> > Jeroen
2013-03-19 by raabje
Okay, thanks, have to input some dummy CC values that have no use on all 16 tracks. I will save this pattern at location 000.
so my settings are:
- multi mode
- midi merge on --> for playing external controllers for external synths
- rechanalize input: always, so I don't have to set midi channel on external controllers
- midi track 1 to 7: external, for sequencing external synths
- midi enable: track 1 to 7: off, for not hearing the internal synth engine when playing the pads or an external controller
- keyboard channel: basic
- program change off for channel 1 to 7, so changing presets on the external synth doesn't mess up internal presets, or visa versa
There is a difference between internal synth engine and sequencer, settings for sequencings external synths doesn't automatically shut off the internal synth engine for that midi tracks. Took me some time to get familiar with this concept.
> Steve
> > > Hello group,
> > > Any help?
> > > bye,
> > > Jeroen
2013-03-19 by Matt
I believe if u turn midi off u dont need the dummy midi data since it doesnt matter what preset its on since its not making sound anyway
Just my 2 cents its a pain to put it in
so my settings are:
- multi mode
> Steve
> --- In xl7@...m, "raabje" wrote:
> >; I might have the answer:
> > > Hello group,
> > > Any help?
> > > bye,
> > > Jeroen
2013-03-19 by Matt
Thanks for making me menu dive. I forgot altogether u could map program changes to whatever presets u want under midi menu
so my settings are:
- multi mode
> Steve
> > > Hello group,
> > > Any help?
> > > bye,
> > > Jeroen
