Can't run Eloader
2014-12-30 by steph_dumas@...
Hi ,
i got some issues installing the eloader .
The installation was successful but i cant find any launch icon , and i don't know how to launch the program .
Any idea ? i m using win7
Thanks !
2014-12-30 by Robert Van Kuran
Use XP -RVK
> On Dec 30, 2014, at 7:29 AM, "steph_dumas@... [xl7]" <xl7@yahoogroups.com> wrote: > > Hi , > > > > i got some issues installing the eloader . > > > > The installation was successful but i cant find any launch icon , and i don't know how to launch the program . > > > > Any idea ? i m using win7 > > > > Thanks ! > > > > > >
2014-12-31 by peteflagg@...
2014-12-31 by Robert Van Kuran
Yeah, I doubt it will run on modern Windows, as it looks like an old DOS program. I run it on an old Dell Inspiron Win98/DOS laptop that I got off eBay for like $40. The laptop cannot do much at all, not even networking, but it will run my old DOS file conversion and librarian software programs that use internal (non USB) floppy disks. I have to use Midisport midi interface, cause it is the only one I could find that you can get old Win98 drivers for. Maybe you could try it with Win98 compatibility mode?
2015-01-01 by twinstripe_uk@...
2015-01-01 by Robert Van Kuran
I used an XP VM hosted on my Mac Book Pro via Parallels 8.x I used a MIDIsport and the corresponding M-Audio drivers for XP. and loaded perfectly w/ eLoader 1.1 This was with my P2K -RVK
> On Dec 31, 2014, at 5:23 PM, "twinstripe_uk@... [xl7]" <xl7@yahoogroups.com> wrote: > > Definitely won't run on Win7 or above natively, and compatibility mode has been flaky on Win7 32 bit and just plain doesn't work on 64 bit in my experience. > > > Try following the advice in this link: > > http://windows.microsoft.com/en-GB/windows7/install-and-use-windows-xp-mode-in-windows-7 > > > This will (if you're using 'Pro' or above) enable you to run a virtual XP machine, which can also be incredibly useful for running other, older software (as even for stuff it can't run natively, the compatibility mode is much better on XP). > > Incidentally, if you're still having trouble, check your MIDI drivers, as eLoader tends to have issues with some of them (I have a USB - MIDI cable that doesn't work using its own drivers, but works like a charm using eMU ones...) >
2015-01-27 by smw-mail@...
