Advice on backing up all my presets needed
2015-02-12 by electrow2000@...
I need to back up my presets to the computer (Win7 32 or 64bit). I've downloaded the Prodatum editor but I can't tell if it saves all the presets or just one at a time. Maybe I've missed something while reading the manual. If Prodatum is not designed for bulk dumps of presets what is recommended? I understand e-loader is not for saving presets - correct?
Thanks
Re: Advice on backing up all my presets needed
2015-02-13 by rpcfender@...
Just to be clear, you have pressed the MIDI button and are at 'SEND MIDI SYSEX DATA' ?
Cursor down and select say 'bank 0 user presets'
Press the flashing Home/Enter.
The CS send should light and the counter on the manual dump in MidiOx should start counting if you have the connected Midi interface selected as a device in Options/Midi Device... in MidiOx.
This is all that should be required as far as I know and works perfectly on my system.
The fact that you are not seeing Midi out led light up on the CS means the problem is in the CS.
2015-02-13 by electrow2000@...
Thank you rpcfender. The answer is yes and as I was dreading midi out doesn't light. I hate to go into diagnostics mode without first having backed up my presets - back to square one, I guess.
Re: [xl7] Re: Advice on backing up all my presets needed
2015-02-13 by First Last
does your midi device support sysex?  a lot of them dont these days
     On Thursday, February 12, 2015 10:23 PM, "electrow2000@... [xl7]" <xl7@yahoogroups.com> wrote:
     Thank you rpcfender. The answer is yes and as I was dreading midi out doesn't light. I hate to go into diagnostics mode without first having backed up my presets - back to square one, I guess.  #yiv2293492368 #yiv2293492368 -- #yiv2293492368ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv2293492368 #yiv2293492368ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv2293492368 #yiv2293492368ygrp-mkp #yiv2293492368hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv2293492368 #yiv2293492368ygrp-mkp #yiv2293492368ads {margin-bottom:10px;}#yiv2293492368 #yiv2293492368ygrp-mkp .yiv2293492368ad {padding:0 0;}#yiv2293492368 #yiv2293492368ygrp-mkp .yiv2293492368ad p {margin:0;}#yiv2293492368 #yiv2293492368ygrp-mkp .yiv2293492368ad a {color:#0000ff;text-decoration:none;}#yiv2293492368 #yiv2293492368ygrp-sponsor #yiv2293492368ygrp-lc {font-family:Arial;}#yiv2293492368 #yiv2293492368ygrp-sponsor #yiv2293492368ygrp-lc #yiv2293492368hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv2293492368 #yiv2293492368ygrp-sponsor #yiv2293492368ygrp-lc .yiv2293492368ad {margin-bottom:10px;padding:0 0;}#yiv2293492368 #yiv2293492368actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv2293492368 #yiv2293492368activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv2293492368 #yiv2293492368activity span {font-weight:700;}#yiv2293492368 #yiv2293492368activity span:first-child {text-transform:uppercase;}#yiv2293492368 #yiv2293492368activity span a {color:#5085b6;text-decoration:none;}#yiv2293492368 #yiv2293492368activity span span {color:#ff7900;}#yiv2293492368 #yiv2293492368activity span .yiv2293492368underline {text-decoration:underline;}#yiv2293492368 .yiv2293492368attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv2293492368 .yiv2293492368attach div a {text-decoration:none;}#yiv2293492368 .yiv2293492368attach img {border:none;padding-right:5px;}#yiv2293492368 .yiv2293492368attach label {display:block;margin-bottom:5px;}#yiv2293492368 .yiv2293492368attach label a {text-decoration:none;}#yiv2293492368 blockquote {margin:0 0 0 4px;}#yiv2293492368 .yiv2293492368bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv2293492368 .yiv2293492368bold a {text-decoration:none;}#yiv2293492368 dd.yiv2293492368last p a {font-family:Verdana;font-weight:700;}#yiv2293492368 dd.yiv2293492368last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv2293492368 dd.yiv2293492368last p span.yiv2293492368yshortcuts {margin-right:0;}#yiv2293492368 div.yiv2293492368attach-table div div a {text-decoration:none;}#yiv2293492368 div.yiv2293492368attach-table {width:400px;}#yiv2293492368 div.yiv2293492368file-title a, #yiv2293492368 div.yiv2293492368file-title a:active, #yiv2293492368 div.yiv2293492368file-title a:hover, #yiv2293492368 div.yiv2293492368file-title a:visited {text-decoration:none;}#yiv2293492368 div.yiv2293492368photo-title a, #yiv2293492368 div.yiv2293492368photo-title a:active, #yiv2293492368 div.yiv2293492368photo-title a:hover, #yiv2293492368 div.yiv2293492368photo-title a:visited {text-decoration:none;}#yiv2293492368 div#yiv2293492368ygrp-mlmsg #yiv2293492368ygrp-msg p a span.yiv2293492368yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv2293492368 .yiv2293492368green {color:#628c2a;}#yiv2293492368 .yiv2293492368MsoNormal {margin:0 0 0 0;}#yiv2293492368 o {font-size:0;}#yiv2293492368 #yiv2293492368photos div {float:left;width:72px;}#yiv2293492368 #yiv2293492368photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#yiv2293492368 #yiv2293492368photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv2293492368 #yiv2293492368reco-category {font-size:77%;}#yiv2293492368 #yiv2293492368reco-desc {font-size:77%;}#yiv2293492368 .yiv2293492368replbq {margin:4px;}#yiv2293492368 #yiv2293492368ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv2293492368 #yiv2293492368ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv2293492368 #yiv2293492368ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv2293492368 #yiv2293492368ygrp-mlmsg select, #yiv2293492368 input, #yiv2293492368 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv2293492368 #yiv2293492368ygrp-mlmsg pre, #yiv2293492368 code {font:115% monospace;}#yiv2293492368 #yiv2293492368ygrp-mlmsg * {line-height:1.22em;}#yiv2293492368 #yiv2293492368ygrp-mlmsg #yiv2293492368logo {padding-bottom:10px;}#yiv2293492368 #yiv2293492368ygrp-msg p a {font-family:Verdana;}#yiv2293492368 #yiv2293492368ygrp-msg p#yiv2293492368attach-count span {color:#1E66AE;font-weight:700;}#yiv2293492368 #yiv2293492368ygrp-reco #yiv2293492368reco-head {color:#ff7900;font-weight:700;}#yiv2293492368 #yiv2293492368ygrp-reco {margin-bottom:20px;padding:0px;}#yiv2293492368 #yiv2293492368ygrp-sponsor #yiv2293492368ov li a {font-size:130%;text-decoration:none;}#yiv2293492368 #yiv2293492368ygrp-sponsor #yiv2293492368ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv2293492368 #yiv2293492368ygrp-sponsor #yiv2293492368ov ul {margin:0;padding:0 0 0 8px;}#yiv2293492368 #yiv2293492368ygrp-text {font-family:Georgia;}#yiv2293492368 #yiv2293492368ygrp-text p {margin:0 0 1em 0;}#yiv2293492368 #yiv2293492368ygrp-text tt {font-size:120%;}#yiv2293492368 #yiv2293492368ygrp-vital ul li:last-child {border-right:none !important;}#yiv2293492368
