Re: [xl7] filter bypass
2015-03-17 by eidorian@...
On 2015-03-16 21:29, topgeneral2002@... [xl7] wrote:
> Hello all I want to send the sounds from my MP7 through my se1x but I
> want to bypass some or all effects from the mp7 so that the se1x is
> doing the job. How can I bypass the filter of the mp7 and other
> effects?
>  Thanks
>  Reginald
You can turn effects off easily enough (Global Menu -> Master Effects
-> FX Mode -> disabled), but filters are per-note played and often have
shape which changes over time.  So unless you're using the MP7 as a
monosynth (or one monosynth per audio output jack I guess) you will be
rather limited on what filter shaping you can achieve on notes
(basically you'd end up with a paraphonic filter like the Korg Poly-800,
at best).  I very much doubt there's a feature to "turn the filter off"
(i.e. open the cutoff frequency to maximum and set resonance to 0)
globally - it's hard to see why anyone would want do that, so I wouldn't
expect EMU to put that functionality in.  I've seen nothing in the
manual about it.
A.
