Using Command Station and Emulator X3 together
2015-09-08 by Adsr Multimedia
2015-09-08 by D F Tweedie
I'm interested in this subject as well. DF CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
From: "Adsr Multimedia adsr.multimedia@... [xl7]" <xl7@yahoogroups.com>
To: xl7@...m
Sent: Tuesday, September 8, 2015 3:47 AM
Subject: [xl7] Using Command Station and Emulator X3 together
Hello,
I would be happy to hear about using a Command Station and Emulator X3 (PC) together.
Good and bad sides. Any pitfalls? Controls?
Are the official soundsets for the X3 to play from a CS without extensive set-up / customization?
Any other info worth mentioning is appreciated, too.
Thanks in advance,
Zsolt2015-09-09 by Adsr Multimedia
Hello Zsolt,Glad to answer this question, yes, I tried it for a week. Shame on me, but the Emulator X3 was cracked, because I couldn't find one for buy, and maybe this was the cause of periodical program termination without any message or crash. Between two termination I was able to set up the software for reaching totally controllable behavior by CS in program mode. It has exactly the same number of knobs what X3 interface has, but sadly they have different CC settings natively, so you have to set up one of them. I was really satisfied, it can be controlled same way as the CS, but software presets contains a bit different knob-assignments than other on the physical roms.Regards,BarnabásOn Tuesday, September 8, 2015 12:47 PM, "Adsr Multimedia adsr.multimedia@... [xl7]" <xl7@yahoogroups.com> wrote:
ZsoltThanks in advance,Any other info worth mentioning is appreciated, too.Are the official soundsets for the X3 to play from a CS without extensive set-up / customization?Good and bad sides. Any pitfalls? Controls?Hello,I would be happy to hear about using a Command Station and Emulator X3 (PC) together.
2015-09-11 by smw-mail@...
