Periodic click on outputs
2002-04-10 by grimleyj2000
Anybody else noticed this?  Up until I upgraded the OS I have had my
XL7 connected via SPDIF to my digital mixer.  Every once in a while
I would here a loud click/pop over my monitors from the XL7.  I
thought it was a clock sync issue.  However, since upgrading to the
new OS I have been exclusively using the XL7 with headphones (keeps
my legs warm while sitting on the bed).  Sony MDR-7506 Pros to be
exact.  Anyway, I am still hearing the pop/click ... OK so only
twice in the last few days.  Definitely not as frequently as
before ... but still there.
Justin.
RE: [xl7] Periodic click on outputs
2002-04-10 by Andre Lewis
disconnect the digital all together?
Sent: Tuesday, April 09, 2002 9:12 PM
To: xl7@yahoogroups.com
Subject: [xl7] Periodic click on outputs
Justin.
Re: Periodic click on outputs
Sorry, I should have made this more clear.
The SPDIF cable is disconnected.  The only thing connected to my XL7
apart from the AC cord, are my headphones.
-Justin.
> From: grimleyj2000 [mailto:grimley@i...]
> To: xl7@y...
my
while
(keeps
> Justin.
> xl7-unsubscribe@y...
Re: [xl7] Periodic click on outputs
2002-04-10 by erik_magrini@Baxter.com
I get that too sometimes (with all the OS's BTW) when the level is too
loud, or I've got some crazy resonances going on in a patch.  Try turning
down the volume a bit and see if that helps!
rEalm
"grimleyj2000" <grimley@...>
04/09/02 11:11 PM
Please respond to xl7
        cc:
Justin.
2002-04-13 by smwither2002
I've noticed clicks and pops as well with some patterns, and it seems
to happen only when I've changed a preset within the pattern.  Could
be a sudden envelope(decay)transition?  If I replace the preset again
with a more percussive one the clicks disappear.
The new OS is great, BTW.  I haven't really used the Beats mode yet
but just the general tightness and improved reliability (no freeze-
ups!)are wonderful.
E-mu rocks!
2002-04-13 by grimleyj2000
Actually, any time that I notice the pop/click, the XL7 is not
playing anything ... the sequencer is stopped and no sounds are
being played.
-grimley
seems
Could
again
yet
> ups!)are wonderful.
> E-mu rocks!
2002-04-14 by mikexl7
One thought I have on that is this.
This could be a power surge from sompthing being turned on or off in
you house, like a washer of dryer.  Is you xl pluged in on a circut
in your house with sompthing like this?
that could be it.\
Mike
> being played.
> -grimley
> seems
> Could
> again
> yet
freeze-
> > ups!)are wonderful.
> > E-mu rocks!
2002-04-17 by blueriv
I do get clicks all over the place if I combine certain presets
together in a sequence on my P2500. IE; using the following preset
together: If I use preset 000/bank3 "Richness" with 15 other tracks,
and use it again on a second or third track, it happens all the
time.  Also if you use a "Lead" category (monophonic) preset in a
multi channel sequence it happens. Try using a polyphonic preset
instead (this was the solution EMU gave me). Yes I did call them to
describe the problem.... It has to do with the presets, not sure what
causes it ! -Steve
in
> that could be it.\
> Mike
> > being played.
> > -grimley
> > seems
> > Could
> > again
> > yet
> freeze-
> > > ups!)are wonderful.
> > > E-mu rocks!
