BTS - Triggering from the Sequencer (Beats Mode)
2016-10-27 by forums@...
Hi all
Im running the latest OS in both my Command Station XL7 and 2500 and have tried the below in both units.
Choosing a BTS preset and playing (say) C1 will trigger the BTS Kick drum pattern. However, if I then program C1 into the sequencer and press Play, it will only trigger a single Kick and not the BTS pattern.
I have looked at all the Beat settings but can not work out how to trigger BTS beats from a programmed Command Station sequencer? Is this possible?
Many Thanks,
Re: BTS - Triggering from the Sequencer (Beats Mode)
2016-10-28 by smw-mail@...
I am not at my gear now. If no one else has the answer, I can look into this on the weekend.
I thought triggers were recordable, but I will have to double check. A workaround would be to record the bts pattern. A more cumbersome workaround might be to use embedded sysex--but if there's a more direct method, I'd recommend that.
Maybe someone else can spell out the direct steps if its possible. If not, I might have enough of a brain left this evening to give it a test.
Steve
http://www.e-univercity.com/SynthGearDocs/
Not sure, but maybe this is what you need:
Take a look at E-MU Docs > Command Station > Command Station 2.0 Addendum - page 21 of 22.
Is your gear set up to transmit riffs? My thinking is as follows:
BTS sequences are special 16-track riffs.
The sequencer and the sound module are best thought of as independent (but connected) systems.
If the sequencer is going to trigger a bts riff, there has to be communication between the two systems.
Also look at the Addendum for OS 1.31.
Do you have the trigger note on the correct channel (i.e., the channel designated at the Beats Mode TrigCh?
If the bts are triggered from the basic channel, but the C1 in the sequencer is not coming from the Basic channel, that might be part of the problem.
Finally, look at the flow charts (aka block diagrams) at the back of the OS 1.31 Addendum (esp. the one on page 26--triggers and programmable knobs). I am not sure this is affecting what you are trying to do, but it couldn't hurt to make sure your settings are such that the data from the sequencer is going to the sound module in the way you want. This may not be relevant, though; I usually refer to it when making sure midi data is going into the sequencer.
Hope this helps.
Steve
2016-10-29 by smw-mail@...
I tried a little today. The solution depends also on your beats trigger settings/beats key layout. I think I had the same thing you did until I inserted a Strt/Stp trigger into the sequence at the beginning. For me it's a C-2. I'm just getting started on this, but realized I forgot to say anything about this. Will try to home it down tomorrow.
Re: [xl7] Re: BTS - Triggering from the Sequencer (Beats Mode)
2016-10-29 by punkdISCO
Hey Steve - thanks for the replies.
Just been trying again but without success.
From a Midi keyboard, I can trigger a BTS part with say C-1 but recording that key turns it into a single hit rather than starting the BTS part..
I've tried the same from the XL7 drum pads with exactly the same results..
 Pretty knowledgeable with BTS but have never tried to trigger from the internal sequencer. Maybe it is not possible but this would seem a bit daft..
Thanks again
London
www.punkdisco.co.uk
2016-10-30 by smw-mail@...
Friday I played around with triggering BTS from the audition button and then recording some notes, busy beats, and vari beats. Yesterday I played around trying to insert events into the sequencer manually (plus pan changes from my usb keyboard so I can see and hear my connection). Also, I tried recording the C-2 Start/Stop Beats Trigger, latched along with C-1 as Parts 1, latched). Today, I am going to systematically try a few ways to get the sequencer to turn the BTS sequencer on and off (writing down my settings and changes as I go). The sequence from yesterday doesn't seem to be turning on the BTS sequencer, though it is playing the data I recorded--basically what you discovered.
If I cannot get the BTS sequencer to start/stop from within the sequence, I will see if I can do it using an embedded sysex command--first by issuing an audition command.
Maybe I can figure this out.
RE: [xl7] Re: BTS - Triggering from the Sequencer (Beats Mode)
2016-10-30 by foRUMS 4 punkdISCO
Hi again
Im guessing that if you are getting the same results, it really is not possible.  I just printed out the BTS section from the manual and Im back in front of the 2500 in about 1 hour and have a few little hunches (but nothing that I have not probably tried already)..
Up to now I have only used the BTS riffs externally from Ableton Live and they work fine.  It took me a few days to realise that there is only 1 BTS part allowed out of the 16 multi timbral parts โ€“ this does not seem to be particularly clear from the manual but once you know this, it is fine.  Moreover, the BTS part has to be setup in the multi setup (I think I always have it as part 1 but donโ€™t recall).
Anyway, more testing later..
Thanks again,
London
www.punkdisco.co.uk
Sent: 30 October 2016 12:31
To: xl7@yahoogroups.com
Subject: Re: [xl7] Re: BTS - Triggering from the Sequencer (Beats Mode)
2016-11-01 by punkdISCO
Hi Bruno and Steve
"I would suggest you to try the MIDI loopback then."
I think it's fair to say you can not internally sequence BTS frogs. ๐Ÿ˜€
The work around I'm going to use in my stand alone hotel room is to just record the BTS patterns back into the same Track. This works fine and actually then allows editing. The setup is simple:
1) midi Out1 to midi In
2) make sure Transmit Riffs is on
3) Use the track mute buttons to trigger the BTS parts
4) Hit record (u will hear chorusing as the parts are double triggered whilst recording)
The only slightly tricky bit is you have to press record and the BTS part at the same time or start the BTS on the second loop. But with Quantisation this is fine.
Thanks again for all you help.
London
www.punkdisco.co.uk
> On 30 Oct 2016, at 16:00, Bruno brunorc@... [xl7] <xl7@yahoogroups.com> wrote:
2016-11-01 by smw-mail@...
Yes; no need to use an external computer for the loopback with your setup since the midi in is available. Thanks for writing up the steps and adding them to the thread. For my example (since I was using C01B as my BTS preset and C16B as my BTS trigger--and routing), I believe I was routing midi in either to port B or maybe both.
At some point I might play around with embedding a sysex command to start the bts clock. However, I am wondering if it could be done with a BTS note trigger saved in a pattern template. One thing I didn't get around was the fact that in latch mode, those triggers toggle between off and on. I did play around with 1-bar mode triggers, which I suppose if I created a 32-bar pattern template with a 1-bar trigger at the beginning of each bar that would avoid the on/off toggle problem of latch mode.
I'd be very interested in knowing whatever other techniques you come up with.
Thanks for posting the question!!!! Sunday afternoon I actually used the test setup I came up with for tackling your question for some improvs as part of the Halloween event at electro-music.com. I had BTS part 1 (bass drum) latched, with parts 2-16 in 1-bar mode. While playing a usb keyboard going to the P2500 (I rotate through the channels to layer stuff), I had a blast reaching over and swiping bunches of the 1-bar trigger buttons. Since it was a Halloween event, I tried to make it creepy, but some of the comments in chat said it sound more like it was coming from a mental institution than creepy. I would not have had such fun if I hadn't been tackling your question. (It was the fun of a "madman" jamming out on the P2500--perfect for the Halloween event!!)
Steve
2016-11-01 by Bruno
I think it's not possible, because internal arps, audition riffs and bts patterns fall into the same category, and one excludes another. External arps - as we established - won't trigger bts patterns, only single notes.
2016-11-01 16:44 GMT+01:00 smw-mail@... [xl7] <xl7@yahoogroups.com>:
Just wondering: Has anyone used an arp to toggle (or play) bts parts triggers? Might be cool or might be totally messy, if it's even possible. Hmmmmmm.
2016-11-03 by smw-mail@...
Yeah--this makes sense, though yesterday I tried it with the midi-ox based loopback technique (since I had it set up from Sunday morning's experiment) and I think I had the bts riff playing another preset in addition to the bts parts (i.e., just re-routing the riff notes for some of the 16 parts of the bts sequence to another preset). Although I played around with the receiving preset as an arp preset, all I seemed to be doing was just playing the triggered bts parts with a second preset (kind of the reverse of what I was wondering about). I was way too tired, otherwise I might have tried it with the P2500 also sending out arps (and looping them back in).
I believe for the reason you mentioned, neither the riff notes nor the arp notes cab be routed internally to other arps or bts presets (though sometime when I am well rested, I may just see where the loopback technique leads--purely for the experimental fun of it.
Steve
2016-11-05 by Bruno
Wow, Steve, that was a real research. Much appreciated! I spend my day far less productive (with kids on the b'day party), and it's evening here, so I'm not able to comprehend it, but I will certainly revisit the thread, once my head is fresher.
Thanks a lot!
Bruno
2016-11-05 15:42 GMT+01:00 smw-mail@... [xl7] <xl7@yahoogroups.com>:
These are just some footnotes on the setup and interaction of beats and arps.
Test routing/setup {Meats Mode Setup page in Arp Menu system]:
BtsCh:16B - meaning button triggers and midi note triggers will play the bts preset on C16B if enabled.
TrigCh = 01B - meaning midi note triggers coming from channel 01 on port B will decide which parts/groups/functions to activate or toggle on/off depending on settings.
Beats parts can be triggered (momentary, 1-bar, latched) from function buttons.
Beats parts, groups, and other beats functions can simultaneously be triggered (activated or toggled) from external midi notes.
With all beats parts set up as latched, both the trigger buttons and the assigned midi notes will toggle a parts on and off. Midi notes assigned to groups will toggle all parts assigned to that group.
Midi notes seem to have bts priority. In other words from the trigger channel [01B in my test setup] any notes assigned as beats triggers (as per the BEATS KEY LAYOUT page in the arp menu system) will not play the preset on C01B, but will be directed to the BEATS system--and will toggle or activate Beats on the BtsCh. Any midi notes not assigned as beats triggers will be passed through to the preset on the trigger channel (01B in my test setup), not the beats channel (16B in my test setup).
Here's where the midi loopback technique can be used with arps to trigger beats parts (or groups and functions, I suppose).
Current settings include:
arp preset on trigger channel (01B)
transmit arps to midi is on and midi-ox is sending the arp notes back in [looping back]
sustain CC is on for trigger channel (01B)--basically
(1) to latch the arp pattern and
(2) to prevent the looped back note from turning the arp off.
[my test arp [S01] currently starts at Key = +0; it doesn't need to be]
The result:
Once the arp has been started the lopped back notes toggle beats parts.
For example, if I start beats with the triggers/parts on as follows:
T1, T3, T5, T7 on; T2, T4, T6, T8 off
I can have the arp so that with each step of the sequencer [both bts and arps are 1:1 as far as tempo) the triggers toggle. T1 goes off, then T2 goes on, then T3 goes off, then T4 goes on, etc.
The way I have my test setup, the triggers are chromatic C1, C# 1, D1, etc.
IMPORTANT: If I press C1 on the midi keyboard to try to start the arp, the arp never starts!!!!!!! This is because C1 is being intercepted by the Beats system [BEATS KEY LAYOUT settings] and is used to toggle or activate my Part 1 trigger [T1]. Midi note C1 toggles T1 (because I have it latched), the arp (on C01B) is not started, and no arps are therefore transmitted out and looped back in.
HOWEVER (also important) if I start the arp by playing B0 [one note below] the arps starts, steps 2, 3, 4, etc. play on C01B, are transmitted out, are looped back in, and continue because I have the arp effectively latched on by the CC sustain.
I can watch the trigger leds go on and off to verify the arp is indeed toggling the beats parts. For my test, I have the arp preset playing notes 9i.e., making sounds) but that doesn't seem to be necessary.
Bonus: If I have the display set to C16B, I can play the quick edit busy beats and vari beats CCs while the beats sequencer and the arp loopback toggles also do their thing. Or, I suppose I can map those CCs to two of my keyboards sliders.
Now, I assume if I can do this with external midi, maybe it can be done with midi notes as triggers on a dedicated drummer track in a pattern. I think I'll save that experiment for another day; but if it can be done, I can envision setting up a pattern template + multisetup for my own E-Mu based self-contained "addictive drums"; with programmed variety.
2016-11-05 by punkdISCO
Nice... big thanks for this. Defo going to have a play tomorrow when back in the studio..
Nice one..
London
www.punkdisco.co.uk
> The result:
> Now, I assume if I can do this with external midi, maybe it can be done with midi notes as triggers on a dedicated drummer track in a pattern.  I think I'll save that experiment for another day; but if it can be done, I can envision setting up a pattern template + multisetup for my own E-Mu based self-contained "addictive drums" with programmed variety.
2016-11-07 by smw-mail@...
I just discovered something else related to the interaction between arps and bts. I think I know what's going on, but let me explain the discovery first. This was with one of my newly created my Brp:* [Bts+arp] presets--one that only had a ROM Instrument on L1 (Same 01B trigger channel, 16B bts channel; makes no difference if midi is looped back or not--i.e., it seems to be an internal interaction.)
Trigger 1 [part 1] from either the keyboard or the button starts a BD 1/4 note [i.e., 4 per measure] constant pattern.
When trigger 3 [part 3} is started, the BD only plays on the 1 [i.e., 1 BD at the start of the measure].
When I switch the arp status within the Brp.* preset from on to off, the missing BD hits on 2, 3, and 4 return.
Changing the pattern speed of the arpeggiator (which was 1/4x) changes the number of times the BD [from trigger 1] and/or the HH [from trigger 3} play(s) within the span of the beat per measure.
All of this has been done with triggers in latch mode; so, my guess is that the arp note is turning off the 2nd, 3rd, and 4th BD hits before it gets to sound. at 1/4x for the arp speed, this note cancellation happens from 50 BPM to 300 BPM (and probably at lower BPMs, but at 001, I got tired of waiting!)
I looked at the midi output and I think that is what is going on, although it seems that for the BD hits that do sound (as well as the HH hits), the midi notes are doubled and for the missing BD hits, there is only one on but 2 offs. When the preset arp status is switched from on to off, there is one BD note off for every
BD note on (likewise for the HH hits).
Again, since this is being done without an external midi loopback, I am include to say the interaction between the beat and the arp is internal.
How to make intentional use of this feature in either a predictable or predictably random way is beyond my comprehension at the moment.
Steve
Mystery: Per Note CC64 (sustain) & ext clock [ was: Re: [xl7] Re: BTS - Triggering from the Sequencer (Beats Mode)
2017-03-26 by smw-mail@...
Here's a potential mystery--at least it's a mystery to me at the moment. It is something I hope to understand in the same vein as some other deep explorations into the E-Mu synth engine. Since I don't have time to track it down now, here's what happened. (Maybe someone else can explain what is going on.)
Yesterday I did a live (in home) performance with a usb/midi keyboard connected to my P2500. I did my usual thing of setting up presets on the different midi channels, so I could change the global midi channel on the controller and play each P2500 Channel/Preset [C01A-C16A] one at a time. The 16 buttons were set up to play a BTS drum pattern/beats on C16B.
For C01A-C16A, I have a knob on the keyboard set up to CC 64 (sustain on/off) so I can layer arps, bpm, and other presets that have internal auditory motion--such as through LFO sound shaping on up to 16 channels.
The midi clock was set to ext so I could slave it to the midi clock serving other gear. (This seems to be important to the effect experienced todayI)
At power up (and when I reset the settings from the multi-setup I saved), the midi clock clock is set to ext. The current clock at power up a tempo (120). When I change the tempo via the display/data knob, the mysterious effect disappears but returns when I restore the multi with midi clock = ext.
The current tempo remains at what I last had (e.g., 80 or 20 or whatever).
THE MYSTERIOUS EFFECT(S):
With the midi clock at ext, but with a numerical tempo displayed, it seems that one of the LFOs with a bpm rate (1/4 in this case) is picking up the bpm clock from the same source which drives the displayed clock (i.e., not the ext midi clock, because I have no ext midi clock coming into the P2500.
I have seen the residual current tempo before, but until now it never occurred to me that there might be potential for multiple clocks--one ext and one internal. (Has anyone else seen or taken advantage of this?)
The REAL Mystery--which seems like per note CC 64 (sustain on/off):
First of all, the preset I had on C01A is XROM arp:Palomar; the arp does not play [probably because the arp is expecting to get its bpm from ext]; LFO2 has a square wave octave modulation at 1/4 bpm evidently picked up from the "current" tempo.
If I press a note and then turn CC64 on, the preset (with its square wave modulated octave effect) sustains. When I press a different note, that' too sustains.
When I turn CC64 to 0, those notes continue to sustain as if they are latched. I can play other notes and they don't sustain. When I press the keys for the sustaining notes (one at a time), they turn off (one at a time). And, no, it is entirely independent of my global/button latch settings.
Am I missing something? like a per preset latching thing? I haven't looked, but I suppose there could be patchcords (flip/flop?) set up as sustain toggles that seem to function as per note CC64 sustains due to dynamic note assignment at playtime?
It might be something very simple, and I wanted to write this down so I can come back to it to explore, but thought I'd ask here, in case anyone else knows what is eluding me at the moment.
Foot notes:
I have CC28 assigned to MidiL (LFO2 Rate). That changes the rate of the octave jump modulating (square wave or whatever I change it to). I also have CC27 assigned to MidiK (LFO2 Amount) which affects the modulating cutoff frequency
If I turn the arp status off in the preset, the effect that seems to be per note/latching sustain goes stops the sustain on all notes previously sustained and the per note effect no longer works for subsequent notes.
Anyhow, I am now wondering if this is related to the kind of interactivity I explored before. However, I have used up my time allotted to this. Maybe someone else can explain what is going on here.
Steve
