Re: [xl7] TICK 0 vs TICK 1
2002-04-29 by Aaron Eppolito
Okay, here goes. Events at tick 0 (01.01.000) are only editable if the track is set to "ext" only. You may edit things at that tick, you may delete things, but you may not add things. This is because the sequencer uses tick 0 as the location at which to place its setup info if the track is "int" or "both". To prevent user data from being overwritten, that location is not "add-to-able". The only reason tick 0 is visible at all for "ext" tracks is so that you can remove data that might have been written if the track was saved while set to "int" or "both". Events (like program changes, etc) at tick 1 play before notes at tick 0 and do not play after the first loop. This is the place that you should put setup information for your external gear. Basically envision tick 0 as the sequencer's private data setup and tick 1 as the user's data setup. Also note that this data is played slightly ahead of time when switching from pattern to pattern. If that's still not early enough for your Korg, try moving the first notes targeted to the Korg later in time so as to give your Korg plenty of time to do its program change. -Aaron peebs uk wrote:
> Just a thought, the v1.31 manual says that you can view this tick for > removing xl7 presequence setup data from external tracks (but doesn't > mention adding anything in there yourself). Maybe there's a way of getting > some xl7 data in there which can then be changed to an external cc as the > tick only seems visible when there's something already there? > > Does that make any sense, and if so can you think how the xl7 data can be > put in there? > > PS. Tried controlling the korgs for the first time since the change in o/s > and the prog change events at 001.01.001 are still too late. > > >From: "peebs uk" <peebs_uk@...> > >To: xl7@yahoogroups.com > >Subject: Re: [xl7] Re: Prog change msgs to another groovebox/pattern > > > >Thanks for the advice Mike, I think that would do the trick if... I wasn't > >having the same problem as you! Just tried to add a cc event on an external > >only track and the lowest tick I can use is 001.01.001 (running o/s 1.31) > > > >As you're experiencing the same problem should I repost this with the > >subject 'Can't enter event at tick 001.01.000' or has this problem already > >been discussed with no solution? > > > > > > >From: "mikexl7" <mikexl7@...> > > >To: xl7@yahoogroups.com > > > > > >Well there is the ability to place cc info on the tick 001.01.000 in > > >the list editer but mine has stoped working for some unknown > > >reason. Asuming that yours is not doing what mine is just go into > > >the list editer and press the repeat button and then select the cc > > >info to send a program change. > > > > > >P.s. the track has to be set to external to access the tick > > >001.01.000. > > > > > >I think this will work. > > > > > >Mike G
