More on Arp programming + New rEalm Tune (yes, again)
2002-05-14 by erik_magrini@Baxter.com
Do you like to experiment when programming, or do you prefer to have a
goal in mind that you try to program. Like for instance a certain
progression, melody or rythm. The reason I ask is because I am don`t know
much theory and I was curious how much theory others are applying.
>>>I wish I had a simple answer for you, but in all honesty for me it's
combination of experimentation, and knowing exactly what I'm after.  I
taught myself music theory up to a college 4 level (borrowed friends' books), and while I rarely conciously use that
knowledge now, I'm sure it's stuck with me and plays a small factor even
at a subconcious level.  Typically I know what sound I want, and while
trying to set up my arps to reflect that, I usually get side tracked and
start experimenting along the way.  I'm the same way when it comes to
synthesis and making my own Presets.  I start off with a goal and path in
mind, but typically end up with somthing drastically different from that
goal by the time I'm done. <<<
P.S. By the the way realm, I dig all your tunes, keep it up! peace thru
music
>>>Brand new one just up http://rEalm.iuma.com "In The Spiral (2002 Mix)"
rEalm
RE: [xl7] More on Arp programming + New rEalm Tune (yes, again)
2002-05-14 by John Royle
>>>Brand new one just up http://rEalm.iuma.com "In The Spiral (2002 Mix)" <<<
That's definitely your best so far (well IMO anyway!). Maybe it's just the sort of music I like, but it really smacks with attitude, and the pecussion track is sooo detailed and well programmed. How much of that was done on the XL7? How long did it take you?
This e-mail and its attachments are intended for the above named recipient(s) only and may be confidential, legally privileged and protected by law. If you are not a named addressee or have received this transmission in error, please notify us immediately at postmaster@twowaytv.co.uk and then delete this e-mail. As Internet communications are not secure we do not accept legal responsibility for the contents of this message or responsibility for any change made to this message after the original sender sent it. Save for this legal notice, the contents or opinions contained within this e-mail are solely those of the sender and do not necessarily represent those of Two Way TV Ltd unless otherwise specifically stated.
