Re: [xl7] [OT] Midi Merging
2002-05-21 by erik_magrini@Baxter.com
Let me know if you find anything, a friend of mine is in the same quandry
with his Opcode interfaces...
rEalm
"Andre Lewis" <andrel@...>
05/21/02 11:09 AM
Please respond to xl7
To: "Xl7@Yahoogroups. Com" <xl7@yahoogroups.com>
cc: Show quoted textHide quoted text
Subject: [xl7] [OT] Midi Merging Anyone know of a decent midi patchbay? I have two Opcode patchbays but they aren't exceptionally usefull now that they aren't supported and I can't get drivers that work with my computer. That means I don't get multiple output ports from my computer. I want to replace them but they do have a few very usefull features that I would like to replace: Selectively filter: Filter out any kind of midi message and reroute that to another port. This is usefull if I have one device setting the midi clock, and all the other devices sync'ed to it, but don't want the midi note on/off messages or anything else. I can filter out sysex, timecode, note on/off. Bump channels: I can set the port to bump a channel coming in on 1 to channel 2 or whatever. Work Offline exactly the same way as online: I had a Midisport 8x8 and was not impressed. Other than the lack of filtering it also wouldn't allow you to keep your offline patch setup at the same time you were using your computer. You had to disable the USB on the front. Pretty weak. They said it was simply not something they were used to doing. For instance with my Opcode I used to be able to treat the 8 ins and 8 outs as if they were all independant midi devices and set filtering , and routing to each. When online the computer would get whatever was routed to it's ports and the other ports would only get what was routed to them. Multiple configurations: Easy switching of configurations when not hooked to the computer. The other thing to note was the power management on the Midisport. I fried mine since the USB port on it supplies power, as well as the wall wart it comes with. When the unit wasn't shut off properly (someone tripped over the power cord or the clubs circuit breaker went) if the computer was on a UPS then the unit still got voltage supplied on the USB port apparently causing the main chip to fry. They were kind enough to replace it quickly but it was still something which is likely to happen. Anyway I was also trying to track down a product I think is only available in the UK: Philip Rees Little 2M Midi Merge. http://www.philrees.co.uk/products/mergebox.htm Anyone know if these are distributed in the US? Thanks for checking this out, this has been pretty painful ever since Opcode was bought by Gibson. Andre Lewis To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
