controlling VSTi
controlling VSTi
2002-05-24 by coscon23
i got inspired to try this after reading last weeks thread. got pro52
nicely controlled but it won't work with waldorf's attack. anyone
tried this?...
also... cc numbers on the mp7 won't go further than 96 or
something... why don't they go to 126/127?
peter.
Re: controlling VSTi
pro52
> tried this?...
sorry.. i just noticed cc goes up to 119... still, why not all the
way (127)?
on another note... wouldn't it be great to have the possibility to
assign knobs differently for different midichannels? for instance
midich 1=> knobs control pro52, midich 2=> knobs control ppgwave,
etc...
Re: [xl7] Re: controlling VSTi
2002-05-24 by Nick Rothwell
> way (127)?
Values 120..127 aren't controller numbers in that sense; they're
various kinds of mode changes.
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
  upcoming gig at cybersonica, london, june 5th  -- http://www.cybersonica.org
2002-05-24 by Sean Wilhelmsen
> etc...
You can have each knob do something different. Use programmable mode for the
knobs. Each Knob have its own MIDI channel and controller number. You can
save your knob layout within a Multi Setup (global, third page). This allows
you to have 63 custom knob layouts.
sean at e-mu / ensoniq
RE: [xl7] Re: controlling VSTi
2002-05-24 by Andre Lewis
Rather they CAN be used as control changes, however usually the hardware
manufacturer uses them for things like effects block on/off or program change,
bank change etc.
Sent: Friday, May 24, 2002 11:02 AM
To: xl7@yahoogroups.com
Subject: Re: [xl7] Re: controlling VSTi
> way (127)?
thanx sean... as usual my question was probably not clear enough... i
meant changing the knob values in the same pattern/multi-setup for
every track/channel...
so ; pattrn 001, multi-setup 001, tr 1 (ch1) => knob1 value 74, tr2
(ch2) => knob 1 value 67
hope this is a bit more clear... will probably be impossible to
implement in a new OS (just like my idea to have something similar to
TR808's "Intro/Fill In" system)
> > etc...
mode for the
You can
This allows
> bank change etc.
Nope: they're part of the standard: 120 is All Sound Off, 121 is All
Controllers Off, and so on. I suspect that practically every module
out there responds to local control on/off and omni/mono/poly changes
as per the standard, rather than allowing them as data controllers.
For hardware.  I'm saying that you can assign these to various software packages
which don't usually care about such messages, many soft syns, sequencers etc.
I've had tons of gear that behave differently for each kind of message.  My
Alesis Quadraverb 2 used these messages to switch effects blocks on and off, or
to bypass or whatnot.
Sent: Friday, May 24, 2002 1:24 PM
> bank change etc.
