3-EQ modulation trick, for all EMU modules!
2002-05-27 by nifflas
Yay! Just experimented with the E-MU XL-7 for a while and discovered how to set up a 3 band equalizer. Try this. Go into preset editor, Make an one-layer preset you like. It should not use any filters at all. Important: Key velocity should not be routed to the filter at this moment, we'll come back to this later. Now unassign all knobs that has anything to do with the filter. Go into the filter menu, and set cutoff to 127 (and resonance to zero) Copy the first layer you've done now to layer 2 and layer 3. Go back to preset edit, for the first layer, select a 6db (2 order) LP filter. For the second layer, select a 6db BP filter and for the third layer select a 6db HP filter. Now set up the knobs that usually controlls the filters to instead controll the amp of each of the 3 layers. Now you have a 3 band equalizer. Nice isn't it! "But what if I want the key velocity to controll the cutoff point of the filters?" No, this should not be done. Instead, it's better to route the key velocity to the amp of layer 3 (HP) to bring in the high frequencies only when you hit the keys with high velocity... Now you just need to tweak your sound to get it sound just right.... //Nifflas
