cubase problem
cubase problem
2002-05-29 by coscon23
1- deleting pr changes (mp7 gives every part a prg change, deleted
them in key edit, are there any other big midithings going on in mp7
parts? the lag gets slightly less when i mute more midiparts but def.
doesn't go away entirely)
2- messing with preroll (didn't help at all)
3- changing latency on my echo gina24 (this also makes the lag less
heavy, strange though... didn't use any audio so me thinks it
shouldn't do anything)
i changed to the latest gina drivers (allthough i can't imagine it's
the soundcards fault, but changing latency values did change the
midilag after all) but that didn't help.
by the way i use win98lite, cubase 5.0R6, portman 2x4.
i understand this probably isn't a  mp7 problem, but maybe someone on
this group has had some experience with loading mp7 parts in cubase
and can tell me if it works for them?
any help would be greatly appreciated! thanx,
peter.
Re: [xl7] cubase problem
2002-05-29 by erik_magrini@Baxter.com
What's the actual problem?  You listed that you did to try and
troubleshoot, but what is happening? What's your midi port too?
rEalm
coscon23 <coscon@...>
05/29/02 10:55 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] cubase problem
peter.
Re: cubase problem
sheeeet... i normally write my post in wordpad... then copy it into
this posting thing, but i seem to have copied only the last part of
my problem...
here's what's happening... i have made a pattern on the mp7, have put
it into cubase by midifile... if i play it from the top there's an
extreme lag in timing, very bad... it catches up after a bar or so,
then it's tight again. when cycling this timing lag happens every
cyle on bar1, if i cycle from bar 5 (so 5 to 9, instead of 1 to 9)
it's no problem.
you read the rest of my message...
i've now also tried to more or less program the pattern again in
cubase and got it running without problems, so it really seems only
to be a problem when i'm importing midifiles.
sorry for the inconvenience guys... won't happen again i hope!
peter.
> rEalm
> coscon23 <coscon@i...>
> 05/29/02 10:55 AM
>         To:     xl7@y...
>         cc:
mp7
def.
it's
on
> peter.
> xl7-unsubscribe@y...
RE: [xl7] Re: cubase problem
2002-05-29 by Andre Lewis
It's because when you import it it includes all the program change messages and
sysex needed to get the machine in that state.  You should insert an empty bar
at the beginning, set the temp to 65 or so, move all the controll info from tick
0 of the tracks to this first bar, then insert another tempo change at the
beginning of your track.  It's very quick to do from an event list view.  go to
the first actual note event and split the tracks at that time.  Move everything
before that back.
Sent: Wednesday, May 29, 2002 1:56 PM
Subject: [xl7] Re: cubase problem
my problem...
it's no problem.
peter.
> rEalm
> 05/29/02 10:55 AM
>         To:     xl7@y...
>         cc:
mp7
def.
it's
on
> peter.
Re: [xl7] Re: cubase problem
2002-05-30 by erik_magrini@Baxter.com
Here's what's happening.  Basically, when you save a Pattern via E-Loader,
it not only saves all the midi notes and controllers from your pattern,
but also the set up parameters for the Pattern as well.  These include
things like all your program change messages, EFX settings, and some sysex
stuff too I'm sure.  All of this is saved at the very beginning of the
pattern, thus when it loops around in Cubase, Cubase has to send ALL of
that stuff again and again, which is quite a bit of info.  The XL-7 is
optimized for this huge transfer of MIDI data, Cubase is not.  BTW writing
in Cubase from the start doesn't cause this, as none of that set up data
is "prerecorded" yet.
I experienced the exact same thing you described when running Cubase too
while using my MIDI port on the Layla24, so I understand your frustration.
 I borrow my girlfriend's MIDISport 2x2 now when I need to edit
prerecorded Patterns now, and that seemed to fix the problem completely.
You never mentioned what MIDI port you're using, so I'm not sure if that's
an issue with you too.  If you can't try another MIDI port, try deleting
all your PC messages, sysex (in the List Editor), and Aftertouch data.
That should lean things up nicely, and I'm betting you won't get that
glitching again.  Just make sure your EFX and Presets are correct when you
put it back in the XX-7, as they might not be after deleting all of that
info...
rEalm
my problem...
it's no problem.
2002-05-31 by Nick Rothwell
> stuff too I'm sure.
I've looked at an exported SMF from E-loader, and don't see any sysex:
just program/bank changes, volume, pan, and controllers for arp
status.
Doesn't the XL-7 manual state that the pattern sequencer does *not* go
back to Tick 0 when it loops? A software sequencer will.
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
  upcoming gig at cybersonica, london, june 5th  -- http://www.cybersonica.org
2002-05-31 by erik_magrini@Baxter.com
just program/bank changes, volume, pan, and controllers for arp status.
>>>I wasn't sure, that's why I said "might" :) <<<
>>>Exactly my point.  Still, with a fast MIDI port, it still shouldn't be
a problem.  My $700 Layla24 glitches like this when it loops, the $59
MIDIsport 2x2 doesn't, go figure. <<<
rEalm
