E-loader and midi
E-loader and midi
2001-10-05 by Mwl007@aol.com
Let me explain what I'm doing.
1. Ill create a pattern in the xl7 than use the e-loader to export the midi file.
2. Than I open it [midi file] in my sequencing program [I use sonar] and each track plays fine EXCEPT the one's with any type of arppegiation. They sound awful and distorted, nothing like they did in the xl-7. Any thoughts on how to rectify this problem? Thank you very much, any light on this issue would make my day!!!!
Mike
Re: [xl7] E-loader and midi
I just discovered something else as well. If I just open my sequencing program [sonar] the arpegaiator on the xl-7 doesn't work the same when the program isn't on? It doesn't make any sense? Thanks!
2001-10-06 by Aaron Eppolito
Sounds like you have a MIDI loop.  I just starting your sequencer causes
stuff to go wierd, chances are it is set to soft thru.  I've not used
Sonar, but I do use Pro Audio 8.0 and it always does this.  In 8.0, the
parameter is in the "Tools -> Project Options" menu, where if you go to
the Midi Input tab, you can turn Echo mode to Off.
-Aaron
2001-10-06 by Mwl007@aol.com
Ah..... thank you so much!!!! It works beautifully now!  I'll thank you when
I accept my Grammy!
Mike
