thanks Aaron! i'm a try it when i get home---peace
--- In xl7@y..., Aaron Eppolito <aarone+list@e...> wrote:
> Yep. It's per channel though, not track (but that will be
equivalent if
> you haven't changed the routing). Simply set MIX OUTPUT (7th
screen in
> Global) to be the appropriate send for each channel (send1 for the
main
> pair, send2 for the sub1 pair, send3 for the sub2 pair). You'll
> probably also want to turn down the FX send level as well or simply
> disable them on the next screen, otherwise you'll get the dry sound
out
> the subs and wet out the mains (this can be useful too).
> Then, pan each channel to pick just one of the pair you've chosen
(that
> is if you wanted a mono send).
> -Aaron
> hm001us wrote:
> >Hi Just wondering if i could assign tracks to different outputs
so i
> >can mix them down seperately on my mixing board? Does the mp7 let
> >you use the six seperate outs for different tracks?? thanks
