AUDITION
AUDITION
2001-10-12 by www.mp3.com/koering
is there a way to put an sound with AUDITION in your pattern and edit the AUDITION sequence via GRID mode? Or is the AUDITION just one of the ARP´s for da specific sounds?
Re: AUDITION
2001-10-13 by larremu@cs.com
Auditions are actual short sequences. It is possible to "capture" an
audition into a pattern using Realtime Mode on the XL for use and or
editing. The method is a little primative, but it works!
First of all, Auditions transmit to the MIDI out jacks, but not to
the internal sequencer, so, connect a MIDI cable from either MIDI OUT
to the MIDI IN.
Then, call up an empty pattern, unless you are adding to an existing
pattern. Set up the preset (whose Audition you want to capture on the
desired MIDI channel. Set up for Realtime recording on the track #
that matches the desired channel. (You may want to listen to the
Audition to make sure set the pattern length to get the whole
pattern.)Press play to start the sequencer, press Audition Button and
you're good to go!
ALSO, you could fire the Audition to an external software sequencer
if that's easier. Whatever works for ya.
-Larry W. E-mu/Ensoniq
