--- In xl7@y..., "hhceo" <hhceo@y...> wrote:
> Can you delete the factory songs and patterns??
> If so how....?
> thanx
Cut from the Command Station FAQ in the Files section of this forum:
-Is there any way to initialize a Pattern to its default settings?
At this time there is no way to directly Initialize a Pattern. The
easiest way is to select an empty Pattern, then save that to the
Pattern location you want to initialize.
There is another way to do this, but it's only recommended if you
haven't created any User Presets, or if you have them properly backed
up. Power on the Command Station while holding down the two Cursor
buttons to boot into Diagnostic Mode. Now scroll the data wheel until
you get to the option "17 Init Data Except Seq". This will erase all
User data (Presets, Multisetups, User Arps, etc) except for any User
Songs and Patterns you may have. Make sure you do not select "16
Initialize User Data", as that will wipe out ALL of your User data.
sapo
