Re: [xl7] (unknown)
Re: [xl7] (unknown)
2002-10-04 by Jonathan El-Bizri
Yes.
bIz
  To: xl7@yahoogroups.com
  Sent: Friday, October 04, 2002 2:25 PM
  Subject: [xl7] (unknown)
  I just purchased an MP-7 and need assistance grasping the whole
  Effects setup.
  I am wanting to beleive that I have the option to adjust the Effects A
  & B's send level for each unique channel (like you do in MIX mode with
  volume and Pan) but what I am finding is that I have to route each
  channel to one of 4 predefined mix levels.
  Is this correct?
Re: [xl7] (unknown)
2002-12-23 by erik_magrini@Baxter.com
As an example Notator for the Atari had a method where by the "user"
grooves were basically any track on any pattern you wanted (usually the
last pattern, 99).
>>>A lot of programs still kinda do this, though maybe not 16 versions of
User Groove.  Reason and Cubase come to mind. <<<
As it is now I have to import/export to and from Cubase. How do others
feel about this?
>>>That's what I used to do as well, although SX's lack of groove quantize
has put the stop to that now :(  I personally would just rather have some
groove presets stored in the XX-7's for use.  The ability to get User
Grooves would be cool, but unless you change the timing of all the notes
in the Track/Pattern manually (ungh!), how are you going to generate the
original groove? <<<
rEalm
Re: (unknown)
2002-12-23 by jesse_medway <medway808@hotmail.com>
the "user"
> last pattern, 99).
versions of
True, Cubase uses a .prt (part) to get the info from.  I brough up
Notator though because it was a pattern based seq just like the xx-7's
others
> feel about this?
quantize
have some
User
notes
generate the
You could create the grooves in another sequencer.  I use Cubase 5
(not upgrading to SX since there is no midi groove control anymore).
And then when you get the feel right just send the midi file to the
xx-7 via eloader.
Either that or just save the .prt files in Cubase as .mid files and
import those.  I did that already with a bunch of them so I could use
them as guides in the mp-7.  But that means I need to go back and
forth between looking at those tracks (and noting their
timing/velocity data) and then manually adjusting the track I'm
working on.
As it is now I'll probably just load the DNA grooves in Cubase and
set it to 384 time and then look at the computer to see the
timing/velocity and adjust the mp-7 that way.  Two screens would help
the process.
Kind of a pain but I was just reading about how M.A.R.R.S did pump up
the volume and they were step timing an sp12 at double tempo with no
quantize set so they could adjust the timing (it gave them 192's)
And then they seq the bassline on an MC500 but put the 8th notes on
one track and the rest of the notes on another track and ran those
notes only through an outboard delay unit set to a few milliseconds
and adjusted in order to get a swing.  So even we have it pretty easy
now.
Jesse
> rEalm
Re: [xl7] (unknown)
2003-03-28 by james
arps ; abbrev. APPREGIATION ,
succession of notes / chord played in a cyclclic manner
by selecting appregiation / arps and holding the notes down together (or using sustain (triplets work nice:)) or by sequencing single beats or single notes on separate channels multitimbrally in a drum like fashion.
  Sent: Thursday, March 27, 2003 5:23 PM
  Somebody please explain arps to me so I can understand creating my own.
  Do you Yahoo!?
  Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
        Yahoo! Groups Sponsor
Re: [xl7] (unknown)
2003-03-31 by lawrence day
Thanks James,
One more thing to all you XL users. I've seen the ad for the authoring ROM they have available but I know you have to have an E-MU sampler to create your own sound ROMs, as I read...But does anyone know a way around this. I'm a REASON user myself and I love my sounds on PC, is it possible to go about creating my own sound ROM that would be compatible without purchasing another E-MU product, unfortunately I don't own anything else yet.
 james <JDPatch@...> wrote:arps ; abbrev. APPREGIATION ,
  Do you Yahoo!?
Yahoo! Groups SponsorADVERTISEMENT
Do you Yahoo!?
Re: [xl7] (unknown)
2003-03-31 by erik_magrini@Baxter.com
NO other way to do it unfortunately.  You may not have to buy a sampler
though, perhaps the store where you bought your XL-7 from will elt you use
one of theirs one day when they're not busy?  I know my salesperson said
it would be no problem to do that (provided of course I bought the Sample
ROM from them).
rEalm
Re: [xl7] (unknown)
2003-06-11 by erik_magrini@Baxter.com
That's all you really need though, the factory Presets can never be
overwritten, so they're always there.  After you reinitialize the entire
unit, just load in the factory Patterns and Songs, and it should be
exactly as it came from the factory.  The only difference, will be that in
new units the Factory Presets are duplicated in the User Preset section.
Your User Presets will be blank following the reinitialize, which is
really no big deal, who needs two copies of the same sounds?  :P)
rEalm
Erika <erika_ev1@...>
06/11/2003 09:44 AM
Please respond to xl7
        cc:
The only thing I see are the factory songs/patterns.
can I contact EMU to have them send me a new CD?
Re: (unknown)
2003-06-11 by Erika
Cool cool! Thanks! I thought I screwed it up big time!!
Erika
entire
that in
section.
is
> rEalm
> Erika <erika_ev1@y...>
> 06/11/2003 09:44 AM
>         cc:
Re: [xl7] (unknown)
2003-08-06 by erik_magrini@Baxter.com
I hear a voice in the wind....
"FAQ it says, FAQ will tell you all..."  :)
rEalm
Nermin <extra_mayo79@...>
08/05/2003 10:46 AM
        cc:
Hello everone,
When you are in the trigger mode and they are asigned to playing
beats mode, what tracks or patterns is it playing?How do you program
those parts if they are programable?
Thanks
Re: [xl7] (unknown)
2003-12-11 by erik_magrini@Baxter.com
I doubt it's a copyright thing, they never check the files on other groups
I've been on.
rEalm
infradead <infradead@...>
12/10/2003 10:15 PM
        cc:
weird...
i can still download animations but not anthems...
wow...
really weird..
now it won't even let me DL animations...
30 seconds after it would let me..  interesting..
if it is a copyright thing they must have DL'd the zips and checked
the contents..  that seems like a lot of work when you think of how
many yahoo groups there are..
huh..
--- In xl7@yahoogroups.com, "phest2k" <phest2k@y...> wrote:
> Hi all
> Thats wierd,
> I checked after uploading them and they were DLable. Now its not
even
> possible to DL the animation or the anthems zips :(
> I deleted the breakbeat file (probably the most relevant to xx7
> users - and my recommendation ->dubjah )and replaced it and it
dosent
> work again!!!!
> Infradead - did you have any success ?
> It shows the file size.
> I´m not to sure about the yahoo groups thing either ( not dissing
> the xl7 group - its excellant).
> If we could use a p2p you´d have them all, and
> tons more,in minutes :/
> My guess is its a prob with yahoo:
> I´ll stay posted.
> :P aul
The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material.  Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality.  Any review, retransmission, dissemination or other use of , or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited.  If you receive this in error, please contact the sender and delete the material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
Re: [xl7] (unknown)
2004-08-06 by PLASTICEFX@aol.com
In a message dated 8/6/04 3:52:03 AM Eastern Daylight Time,
kmdlicous@... writes:
I need  help, I have been told that the operating
system on the XL-7 has been  updated several times
since it was issued.  My question is how do I  update
mine.  I am currently running OSX on my mac.   Any
suggestiions would be most appreciated.  Thanks   kash
parlor
good luck updating any xl-7 systems on your mac bro!!!
plastic
Re: (unknown)
2004-08-06 by vibesart
It's really not that bad as long as you set things up the right way.
*Boot Mac in OS9
*Open OMS and assign correct Settings and Prefs
*Open Eloader - check for proper MIDI communication - XL<>Mac
*follow the sys update instructions.
I had trouble too at first - and for me the key was really learning
OMS and making the proper settings - once that was done everything
worked fine. I did have times after changing various settings in OMS
and Eloader when no matter what, nothing worked. I usually found that
shutting down and then powering up the entire system including the XL7
and the MIDI interface into the exact same setup eliminated the
problem and then everything worked as indicated.
I have updated the system 2X since then - and the Eloader/OMS setup
has worked great with no problems.
Re: [xl7] (unknown)
2010-09-14 by Bob S.
Thank you and welcome. There really is a wealth of information in the group and it's archives. When you get a chance, browse the past messages on your most sought topics such as ROM burning, opinions on best ROMs and little known features and details of operation. Many of us have been together in this for over 5 years including a specialist in this Emu product line. Please feel free to chime in on any time in our discussions threads....and have fun making music with what I think, is one of the best and most versatile electronic all-in-one ROM-based instruments around.....
Bob
El Segundo, CA
Sent: Monday, September 13, 2010 20:03
Subject: RE: [xl7] (unknown)
he110 groupers and station commanders-
thanx to person/s who moderates and keeps group spam free!
this group is great and a wealth of information for me.
I have been member for years and know my way around xl7 pretty well for my purposes(main hardware seq)- but I like to know and learn about other tips/uses.
- just recently someone mentioned random patch generator (in eloader?)- i will check it out...plus i havent backed up xl7 in quite a while.
cant really see what fuss/combat is about -if people dont agree...oh well.
whether you use custom roms or not this machine is sweeeet!!
I had a 2500 breifly before i switched to xl7- and a huge reason i wanted these was to burn custom roms of my original samples which would save space and set-up for live performance.
found it cheaper and easier to trigger external sampler...but more set-up and room needed. :[
There are so many uses for this machine that not everyone buys for same reason. (if not happy with sounds learn and utilize patchcords, or even try stacking sounds)
since i gave up on custom roms I consider xl7 more of an extensive and stackable inst sample library with good wave forms(4 cards in mine).
the yellow beast is mostly a brain for the other synths/drums in my set-up.
live sequencing/editing is free and easy-
Mach FoX
www.machfox.com
www.myspace.com/machfox
http://www.machfox.bandcamp.com
Mach FoX - USA
Time warped supercharged electro punk with pop overtones... nightmares and lucid dreams...
not defined in black and white or color... but analogue sweet analogue.
Mach FoX delivers what underground 80s satellite radio can't.
Date: Tue, 14 Sep 2010 02:01:18 +0000
Hey, Bob! Do you believe all the immature nonsense going on? I have been very polite and understanding; I try to maintain a positive outlook and try to do my best to help people solve problems/find work arounds with their gear, look up relevant previous discussions from the archives, etc. I have written privately to two of the verbal "combattants" with what I thought was amazing calmness and understanding. But it the nastiness seems to have spread to a third person (maybe more).
As I told you I am a believer of free speech and the thought of moderating people's posts really bothers me. And you shouldn't have to edit posts. I don't know what's gotten into people lately. We have never had this BS here!!!!
I also don't like the idea of booting people (except for spammers). If someone wants to leave, that is their choice.
Now that several people are on moderation, part of me wants to just take them off moderation and tell them to "Grow up." (Like I told my kids, I don't care who started it, both of you need to end it!) Yet, as long as its done, part of me wants to just leave it where it is. In any case, it is a waste of everyone's time. You shouldn't have to edit or even approve/reject thses posts.
My advice is just leave things the way they are--no more editing/approval/rejecting and certainly no more kind, understanding private e-mails to the "combattants." Let the posts just pile up no matter if they are inciteful or benign!!!!!!!
To echo what Greg said, thanks for trying to keep on top of it!!
--Steve
Re: [xl7] (unknown)
2010-09-14 by Mauricio Balma
indeed!
I have been in this group and  other similar ones (command station groups) since
their early beginnings, and I have seen them grow, instead shrinking with time.
This is because, command station has  been increasing his popularity with
time.   Best products prove their supremacy on their area only after years,,
when people realize little by little its capabilities.
Besides there is people here with a good attitude to share their knowledge.  I
have two CS since several years ago, and I keep finding new applications for
them every day
Sent: Tue, September 14, 2010 8:54:24 AM
Subject: Re: [xl7] (unknown)
Bob
El Segundo, CA
>From: Mach FoX
>room needed.  :[
>sounds)
>Mach FoX
>www.machfox.com
>http://www.machfox.bandcamp.com/
>Mach FoX - USA
>lucid dreams...
>From: smw-mail@...
>(maybe more).
>--Steve
Re: [xl7] (unknown)
2011-03-22 by XL-7 Group
Thank's man,
or is there a way to automate which chanels to mute/unmute?
On 21.03.2011, at 22:40, Atom Smasher <atom@...> wrote:
On Mon, 21 Mar 2011, XL-7 Group wrote:
> Normaly i mute/unmute a lot the tracks on live mode. And the question is
> .. , is there a way to set the next mute/unmute tracks but activate them
> just at the end of the pattern?
the only way i can think of...
save the pattern in two locations, let's say "1" and "2". make sure
pattern 2 is saved with all tracks un-muted. do your thing while jamming
on pattern 1, then switch to pattern 2 and all tracks will come in
unmuted.
IIRC, from there you can:
a) switch back to pattern 1 and the track-mutes will be (i think?) as you
left them in pattern 1 before switching to pattern 2, or
b) switch back to pattern 1 using "mute hold" and have both patterns with
all tracks playing.
if anyone else has ideas on this...?
...atom
________________________
http://atom.smasher.org/
762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808
"In the beginning, the universe was created. This
has made a lot of people very angry, and is
generally considered to have been a bad move."
-- Douglas Adams, The Hitch Hiker's Guide to the Galaxy
Re: [xl7] (unknown)
2011-03-22 by Atom Smasher
On Tue, 22 Mar 2011, XL-7 Group wrote:
> Thank's man, or is there a way to automate which chanels to mute/unmute?
you can "erase" data from tracks, but that's a destructive editing
process. again, you might want to make a copy of the pattern and make this
type of edit to the copy.
one other thing i can think of.... if you're using software with the
command station you might be able to enable remote control.
         ...atom
 	"Today every inhabitant of this planet must contemplate the
 	 day when this planet may no longer be habitable. Every man,
 	 woman and child lives under a nuclear sword of Damocles,
 	 hanging by the slenderest of threads, capable of being cut
 	 at any moment by accident or miscalculation or madness."
 		-- John F. Kennedy
Re: [xl7] (unknown)
2011-06-13 by Bob S.
Message removed, member put into moderation.
Member since 2004 !
Bob
Re: [xl7] (unknown)
2011-06-13 by Matt
Email addresses and passwords get compromised all the time. Look at sony. They recently got hacked for all their usernames and passwords. People just reuse the user names and passwords on various sites and then the hackers take advantage of that.
-matt
Member since 2004 !
Bob
Re: (unknown)
2011-06-13 by just john
From the "(unknown)," I wonder if it's from a Hotmail account.  I've gotten some of that from other Hotmailers, so I paid attention when I read this:
http://isc.sans.edu/diary/Spam+from+compromised+Hotmail+accounts/11026
(Also, isn't it funny that when you display this message on the web, the list of messages "in this thread" goes back to 2002?  I guess there's a LOT of Unknowns left in the universe.)
> -matt
> *Message removed, member put into moderation.*
> *Member since 2004 !*
> *Bob*
Re: (unknown)
2011-06-15 by steve_the_composer
Yes. The spammer is a long time member, with a history of normal contributions. So I am inclined to believe it was a hijacked e-mail list and not intentioanl spam. Thanks for catching that. (I get the digest, so didn't see it until after it was deleted.)
Steve
> Member since 2004 !
> Bob
