Meter Changes (again)
2002-10-14 by bass17yl
Well, Aaron said it'd be tricky . . .
I've figured out how to insert the meter change events in the
conductor track of the song, but they're not happening in the right
place.  I inserted a change to 7/8 on measure 40 followed by a
change back to 4/4 on measure 42.  On playback, the change to
7/8 happens around beat 3 of measurre 39.  The change back to
4/4 happens around beat 5 of measure 41.  The result is that the
song is back to 4/4 before the end of the 7/8 pattern, and I get the
same problem I had before I "knew how" to change the meter: ie,
an extra beat is added to the end of the 7/8 pattern.  Basically, it
sounds like no meter changes have been inserted, and the
song's 4/4 setting is still overriding the pattern's 7/8.  But I'm
seeing the meter change; it's just changing early.
Another problem is that when I insert a meter change anywhere
in a song, the first few patterns in the song forget how to loop.  In
other words, an 8 bar step containing a 4-bar pattern (it normally
loops) gives me the 4-bar pattern followed by 4 bars of silence.
If the step is 16 bars, I get the first 4 followed by 12 bars of
silence.  Basically, silence until the next pattern change.
Somewhere around step 3 or 4 (regardless of step length), this
problem goes away, and patterns start looping properly.  It's very
confusing and even more frustrating.
A little help ?!?!?
Clay
