midi channels (Newbie)
2002-10-25 by beatbrother2002
Hi everyone new to the fourm and just bought a mp7 and i must say its
great.  But the problem Im having is with my midi setup.  Ok here gos
I have a triton midi to my mp7 and when I setep the channels to
recieve on ext 1a to 16a and try and save the setup in the mp7 the
channel revert back to the preset of int as so as I change patterns.
Can someone please help me.  thank you in advance Peace!
Re: [xl7] midi channels (Newbie)
2002-10-26 by drK
The track channel assignments are done on a per pattern basis and saved
along with other setup information with each pattern.  But the channel and
external/internal assignments for each track are only saved if the track has
something already recorded on it.  So it is difficult to make a template
pattern that you can load each time you start out to make a track.  But
here's something you might try.
Start with a blank pattern and setup all of the track channel assigns that
you wish to default to something other than the XX7's defaults.  so, for
example, if tracks 1-4 are always controlling channels 1-4 on external MIDI
A set those track's output assignments.
This next part is a trick to force the XX7 to actually save these
assignments.  To do this you need to make the XX7 think there is data
recorded on each of the tracks you are setting up.
The XX7 has a special convention where any non-note even recorded on time
tick 001.01.001 is only used when the pattern is run for the first time and
not on every loop.  See page 53 in the manual for a detailed explanation of
this.  We will use this trick to place a innocuous MIDI event that will
satisfy the XX7's need to have data on a track before it will save the
output assigns.
I chose a MIDI controller command, CC 64 for this role.  This is by
convention the sustain pedal and by setting this value to zero (pedal up)
you are basically starting the pattern the way it would any way - with the
sustain pedal released!
Drop into pattern edit mode and use the TRACK/CHANNEL buttons to go to the
first track that needs to have an output assignment.  Scroll through the
edit commands using the DATA ENTRY CONTROL wheel until you get to EVENT.
Make sure the time display shows 001.01.001.  The ENTER button may be
flashing and if so push this so that you enter the event entry mode.
Now hit REPEAT once which will insert one MIDI event at time 001.01.001.  It
will insert a controller message and the display will read something like:
C01  controller  #7  v:127.
(please note that the C01 in the above will change depending on the channel
assignment currently active for that track when the event entry is done).
Cursor over to the #field (#7 in the example) and dial up a new value of 64
using the DATA ENTRY CONTROL wheel.  Next cursor over to the value field
(v:127 in the example) and change its value to 0 using the DATA ENTRY
CONTROL.  You should now see the following in the LCD:
C01 controller #64  v:0
At this point you now have one track that can retain it's track channel
assignment when the pattern is saved.  But what if you need fifteen more?
Seems like a lot of work.
Well there is an easy shortcut.  Use the COPY edit command to place the MIDI
data of the track you just completed on the clip board.  Then paste that to
each of the other tracks you wish to save channel assignments.  When
finished with all of this and setting those new default channel assignments
name the pattern with something you'll remember and save the pattern to an
easy to get to memory location.  The first bank of USER locations is a prime
place to save library patterns and templates.
To use this you can simply select the template pattern you saved which will
of course load it into the pattern edit buffer. You can from that point
treat it as you would a fresh pattern, except that the track assignments
start out the way you wish.
This may not be the best approach to starting a new pattern though because
it is easy to forget to save the pattern to a new location and you just may
overwrite your hard-won template pattern.  So an alternative is to use the
pattern copy command under the SAVE/COPY menu.
Easy, right? :-)
drk
www.delora.com/music
www.mp3.com/zdrk
drk.iuma.com
