[xl7] Sounds change
[xl7] Sounds change
2002-11-08 by Spoelstra, P.J.
Hello,
I've read it before that others had this problem. Now I have it myself. The
problem is that my presets change all the time on the channels in a pattern,
when I start up my MP-7. This problem started this week when I started
sequencing in my PC, but using the sounds of the command station. I've tried
program change in the inspector of Cubase, setting each sounds for each
channel. But it doens't work that well, because I also reroute the program's
in the command station, but it gives a kind of delay or so (and it's not
because of my soundcard).
 Somewhere, I read a solution of restoring to factory default, but I'm not
so happy with that, there should be a better way.
Please help, I've been working on this a whole day!!!!!!!!
thank you
Philip
