anyone?
anyone?
2001-10-30 by mikexl7@yahoo.com
I am at a total loss here.  there must be someone that has had the
same problem out there.  I am a little conserned considering that
aron from emu has passed by and not touched on this one.  If anyone
has any ideas please feel free to contact me directly, or just post.
thanks again
Mike
"Another thing i am noticing that i dont know how to fix is....
 When i use the defaullt preset to make my own instrament when i use
 the Filter Q quick edit knob it dose not change the sound till the
 next note is played rendering it usless when i need it most.  I use
 it most often to thin out a fat leed or pad wile holding down a
chord
 or note.  How do i change this?  anyone know what i am talking about
 here?"
Re: anyone?
2001-10-30 by bruce@sigalarm.com
I assmue you are using an XL-7, and not some P2K critter.  I have to
say that my XL-7 seems to do this without much problem. The only way
this can get to be confusing is that some presets use more than one
instrument (sample playback voice) in the patch, and there are cases
in the XL presets where moving the filter control knobs won't produce
much of an audible result.
Could this possibly be the case?  Just guessing at the moment, as the
filter controls for my XL do it in real time.
Tell us a bit more about if you are using a factory patch, and if so
which one when you get this problem.  If not, see if you can reproduce
it with a factory sound (then tell us which one)
Bruce
> thanks again
> Mike
> chord
about
>  here?"
