--- Raj <rajah_patel@...> wrote:
> The Soundblaster outputs at 48hz but i'm sure it accepts 44.1 to 48hz
> i'm not sure about the control panel anymore but can't you lock the
> sample rate to external?
All recent SoundBlaster cards run at 48kHz. They will lock to incoming
44.1 however, and sample rate convert it in hardware (a very good
quality conversion, too) to 48kHz.
S/PDIF is a tough beast for to tame for FCC reasons. It's always a
tradeoff between having an extremely crisp signal and radiating too
much radio interference. Add to the mix that PCs are not the most
electrically quiet devices, and you can get S/PDIF dropout, pops,
clicks, etc.
Try all the standard things: high-quality cables, moving cables around,
trying bad quality cables just for kicks (hey, you never know)...
-Aaron
PS. I have my SBLive connected to my Kenwood Dolby Digital amp and when
I turn on my GAS stove, it stops working. Took a few times to figure
out that the spark ignition unit in the stove interferes with the
S/PDIF in the other room...
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
