Volume in Mixer view
2002-12-12 by erik_magrini@Baxter.com
Played with this some more last night and I'm convinced it's a bug.
Happens repeatably, though not every time.  If you change the volume via
the Mixer view and use the data wheel, it doesn't always save that new
value.  Only about 1 in 3 times does it work correctly.
rEalm
i've had that happen before.  Sometimes there are little querky things
like
this that happen..  Go figure.
> Speaking of which, anyone else having problems with settings made to
> volume in the mixer page not being saved everytime?  Ran into this
> last night when I was adjusting the levels of my tracks in a
> pattern.  I would cursor over and use the Data wheel to change the
> volume to what I wanted, then save the pattern.  Sometimes the
> pattern would save with the correct settings, other times the
> previous settings were still retained.
> I tried to use the Stopx3 to reload the pattern parameters (both
> before and after the save), though that didn't solve it either.  This
> was a weird bug to me, as performing the exact same procedure to
> replicate it didn't always work.  Sometimes it would save the
> changes, sometimes it wouldn't.  I couldn't figure out why it did
> this, but I was able to reproduce it readily with numerous patterns.
> I'd say it only saved the changes correctly 1 times in 3.  Anyone
> else confirm this?
> rEalm
Re: [xl7] Volume in Mixer view
2002-12-12 by Aaron Eppolito
> via the Mixer view and use the data wheel, it doesn't always save
that
> new value.  Only about 1 in 3 times does it work correctly.
Yes, this is probably a bug.  I actually found it and fixed it (if it's
the same problem you're having) a couple weeks ago.  It'll be in 2.0.
The symptom of the bug I fixed is as follows:  if you hit stop x3 after
changing a volume, pan, preset, arp, or mix setting, it will reset the
value *if the last selected pattern didn't have the same setting*.
Yeah, wierd, I know.  For example: on pattern A with trk 1 having
volume 74, switch to pattern B with volume 100, change volume, RTZ, it
would reset to 100.
If it's not that, it could also be that you have a volume event at tick
1, so check the list editor.  Or it could be that you are changing the
value of an "ext" track, in which case it won't save internal volume
settings.
-Aaron
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
Re: Volume in Mixer view
2002-12-12 by jesse_medway <medway808@hotmail.com>
That's exactly what I'm getting.
after
it
> would reset to 100.
2002-12-13 by erik_magrini@Baxter.com
That's exactly the bug I was talking about, thanx Aaron.  I was trying to
make all tracks across 6 successive patterns have the same volume, so you
nailed it.
rEalm
would reset to 100.
settings.
-Aaron
Do you Yahoo!?
