So, I would connect it up through the midiman like in the orignal?
Then change the midi settings in Cubase? I will be using Ableton Live
as well to let samples play. And in most cases Live will initiate the
start stop commands to the XL7.
Would it be better to seperate the two pieces of hardware and
dedicate each to its own channel on the 2x2? Can the XL7 have
multiple sources giving it commands?
I have a feeling I am going to have a lot of questions on this and I
dread the first time I have tear this all down and set up somewhere
else.
-Greg
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
> I should have mentioned that if you want to control the XL-7
directly from
> the Karma, then you would just run form the Karanm ou port to the
XL-7's
> in port. If you use Logic or Cubase, those programs will let you
do the
> routing 'virtually' which could be easier than physically swapping
> cables.
> rEalm
> erik_magrini@B...
> 12/17/02 01:50 PM
> Please respond to xl7
> To: xl7@yahoogroups.com
> cc:
> Subject: Re: [xl7] I need my hand held - midi
chaining question
> That should work just fine, just make sure to select the
Midisport's B
> port in E-loader and you should be good to go!
> rEalm
> I got a Karma on Sunday. So now I am going to hook everything
> together and want a second opinion if this would be the right way
to
> slave the XL-7 and still be able to trigger samples on my PC. I am
> using a midiman 2x2.
> So, I am going to go from the Karma's out to the midiman A in.
> The midiman's A out will return to the Karma.
> The midiman's B out port will go into the XL7's in port amd the XL7
> out will route back to the B in on the midiman.
> This should still let me do edits via E-loader and use the Karma as
a
> controller for the XL7 and software, right? Or should I be using
> through port on the Karma?
> I am not a networking type of person. So, I have looking at all of
> the different schematics from all the vendors and I think I need a
> drink. Any help would be appreciated. Thanks in advance.
> -Greg
> To unsubscribe from this group, send an email to:
> xl7-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
