apply effect on a preset
2003-01-08 by Jean Kergutuil
hi everybody and happy new year !!
Does someone know if it's possible to apply an effect (like flanger or
delay) on a preset , and then save that preset with the effect.... ???
>>and perhaps you know the way to do this ????
Thanks a lot
Re: [xl7] apply effect on a preset
2003-01-08 by erik_magrini@Baxter.com
Yes, you can do this but you need to go into the Global Menu and set the
Effects Multimode Control to "Preset on Channel ???".  Where ??? is the
midi channel of the preset you want to save the effects with.
The catch?  This is a global setting, so from now on when you switch
presets, the effects will change as well.  Works fine if you're just
poaying one Preset at a time, like in a band or something, but it's not
good for applying effects to all of the Presets in a Pattern.  Check the
FAQ for more info on the effects implementation in the XL-7.
rEalm
"Jean Kergutuil" <jean.kergutuil@...>
01/08/03 04:24 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] apply effect on a preset
Thanks a lot
2003-01-08 by drK
On 1/8/03 7:39 AM, "erik_magrini@..." <erik_magrini@...>
Having a preset "control" the effects system has one benefit that is not
obvious.  You can create special "effects presets" in order to save settings
and routing for later recall for use across the entire XX-7.  One way to do
this is to just dedicate a synth channel like 16B for effects control and
set the global settings as described above to 16B.  Now any "effects preset"
loaded into 16B will give you a setup usable for the entire XX-7.  This is
superior to using saved setups because it does not have the undesirable side
effect of changing other things you may not want changed.  You can also
change effects on-the-fly between patterns or even inside a pattern, though
I don't know how well the effects system handles rapid changes.
Just another trick for the bag!
drk
www.delora.com/music
www.mp3.com/zdrk
drk.iuma.com
