XL-7 and Reason
2003-01-08 by erik_magrini@Baxter.com
Also, keep in mind I've got some Multisetups in the files section of this list that I designed specifically to use with Reason's instruments (and some other softsynths) using the XL-7 as a controller. You can get them here: http://groups.yahoo.com/group/xl7/files/Soft%20Synth%20Multisetups/ Just load them one at a time into your XL-7 via the midi sequencer of your choice. Then you can quickly select them to use as you switch instruments in Reason. I've included a text file with each Multi that tells you what controls the knobs are mapped to, as well as the midi CC#. These will work with Reason 2.0 as well. rEalm 2. Use Reason as a "rack-o-gear" for the XX-7. The NNXT sampler in Reason is a fairly well specified sampler. the other synths and effects are also fun and complement the XX-7's synth well. [Non-text portions of this message have been removed]
